Creating connection to db error, so can't run webassist scripts
Thread begun 1/09/2019 5:47 am by lr_leal239405 | Last modified 1/09/2019 8:46 am by Ray Borduin | 1310 views | 2 replies |
lr_leal239405
When I test the connection I get 'An unidentified error has occurred'. This is the latest version of Dreamweaver CC. And what is the attached (screenshot) I got when cancelling ? I need to run the DataAssist Search Wizard. This is a Dreamweaver I've been using to create the site and the connection worked before. What could have changed?
When attempt to create a new connection I get the HTTP Error Code 404 (see screenshot 2). There is a testing server and I'm not sure what the mapping msg means.
Thanks for your help.
lr_leal239405
Never mind. By changing site definition and adding www, it was resolved. I found it on a forum. I believe this happened to me before and that was it. Thank you anyways.
Yes... I tell people that when defining your testing server make sure to copy and paste whatever value you have as the Site URL and make sure that you can open it in a browser. Also make sure it isn't changed when viewing... sometimes http:// is changed to https:// or www. is added or removed. The final viewable url is the one that has to be used.
