Even the white page with the sample static charts don't work
Thread begun 9/10/2009 10:26 pm by kakadong | Last modified 9/23/2009 8:54 am by Jason Byrnes | 11084 views | 11 replies |
kakadong
I open a file and want to try if DWC works ,
then i got this error...
see the pic
any information you need shown on the pic .....
kakadong
str_replace("&","?,$_SERVER['QUERY_STRING']):'')
=> str_replace("&","?",$_SERVER['QUERY_STRING']):'')
two place,
then no syntax error
but nothing appears ...........
check it in IE, and nothing appears ....
why the code generate by DWC make so obvious mistake??
and nothing appear???
can anyone help me..?
tom92909Beta Tester
The first thing I notice is that you are missing the following line in your <head>
html:
<script src="Scripts/AC_RunActiveContent.js" type="text/javascript"></script>
</head>
and of course you need to make sure that the .js file is located on the server in the proper path.
Lastly, I did a real quick check for myself with a functional chart I created a few weeks ago using Digital File Pro v2.0.1. I have created a screenshot for you to examine. I assure you it is fully functional utilizing my data coming from a MySQL XML feed with a GET submission calling a specific record ID.
I hope that what I've provided comes of some assistance to you.
Wow, that image attachment is unusable. Let's try straight code instead.
html:
<head>
</head>
<body>
<p>
AC_FL_RunContent( 'codebase','http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0','width','720','height','460','src','DynamicWebCharts/open-flash-chart?data=DynamicWebCharts/Data/graph_dataparser1.php?<?php echo (isset($_SERVER['QUERY_STRING'])?"GET=".str_replace("&","§",$_SERVER['QUERY_STRING']):'');?>','quality','high','pluginspage','http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash','movie','DynamicWebCharts/open-flash-chart?data=DynamicWebCharts/Data/graph_dataparser1.php?<?php echo (isset($_SERVER['QUERY_STRING'])?"GET=".str_replace("&","§",$_SERVER['QUERY_STRING']):'');?>' ); //end AC code
</script>
<noscript>
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="720" height="460"><param name="movie" value="DynamicWebCharts/open-flash-chart.swf?data=DynamicWebCharts/Data/graph_dataparser1.php?<?php echo (isset($_SERVER['QUERY_STRING'])?"GET=".str_replace("&","§",$_SERVER['QUERY_STRING']):'');?>" /><param name="quality" value="high" /><embed src="DynamicWebCharts/open-flash-chart.swf?data=DynamicWebCharts/Data/graph_dataparser1.php?<?php echo (isset($_SERVER['QUERY_STRING'])?"GET=".str_replace("&","§",$_SERVER['QUERY_STRING']):'');?>" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="720" height="460"></embed>
</object>
</noscript>
</p>
</body>
kakadong
Thanks for helping me...
but , can you tell me where the AC_runactivecontent.js is...
I don't have the file...
tom92909Beta Tester
Adobe/Macromedia created the AC_RunActiveContent.js to resolve a Flash Player issue with Internet Explorer. I'm not certain if Microsoft has resolved the issue on their end, but I still believe that having this file available is necessary.
I think you should be able to find the file locally on your PC with a simple search... But try looking at the following location first;
Windows XP / Dreamweaver CS3
C:\Documents and Settings\<your user name>\Application Data\Adobe\Dreamweaver 9\Configuration\ActiveContent\IncludeFiles
I hope that helps.
The script is not needed in his sample because it using the object method to create the flash object and not the javascript method.
I am not able to reproduce the syntax errors that are being added to your page. We will need to look into this with your further to determine the cause. I have created a support ticket for this. To view and edit your support incident, log into your support history:
kakadong
Before any complain ...
Thanks for helping .....
I found the js file
and i copy all your code then paste ...
but it still nothing appears ....
I see the gsg.pdf
it didn't tell me what to do ....
I just want to make a very simple chart on my page ,
but I still don't get one ...
And they tell me don't need any computer language can use the extension well ??????
lie = ="
I understand you frustration. I have created a support ticket so we can look into the cause of the problem. Please log into your support history to view and edit your ticket:
kakadong
In my home, the DWC works perfectly with DW4
but when I am in my office , I got a blank page again...
nothing goes error ....
but nothing appears....
Home: WIN 7 DW4 (english)
Office: WINXP DW4 (english)
thanks for open a ticket for me .
when I am at home , I install DW4 (english) and use DWC happily.
but when I am in office , It become nightmare ....
blank,blank,blank,blank again.....
can any one help me??
Please log into your support history to add information to your ticket:
an engineer will need to contact you to look into this issue with you to find the cause.
