The databridge secure download does not work anymore since the last update
Thread begun 1/07/2019 11:26 am by marcel303333 | Last modified 1/08/2019 12:49 pm by Ray Borduin | 1515 views | 3 replies |
marcel303333
I use Databridge Download (File Manipulation / Download).
Since the last update I have a problem with the correct Filepath.
The path from the database for example /path/to/secure/ and the file file.pdf
From the error Message of File download I get the following path /path/to/secure//file.pdf (double slash)
Is this a known issue? I get this only on mysql_i...
Thanks for your help in advance
It may be encoding the slash. Try using:
WA_DFP_DownloadFile("WA_DownloadResult1", "/usr/home/vewade".($dl->getColumnVal("DateiPfad",false)) ."", "".($dl->getColumnVal("Dateiname",false)) ."", "".($dl->getColumnVal("Dateiname",false)) ."", false, false, false, "", "", "", "");
marcel303333
Thanks a lot Ray,
that did the trick.
Will there be an update of data bridge?
No, this is as designed.
The new version of databridge has built in Cross Site Scripting prevention for security. You have to manually disable it when you have html, javascript, or direct references to code in your column.
You can disable it globally by updating your rsobj.php file. You can disable it on the recordset level, or you can disable it in individual getColumnVal() references. The example I gave you disables it in the getColumnVal() method by appending the "false" parameter at the end.
I think it is best to have the Cross Site Scripting enabled by default, so people will have to get used to making the change in the code in one of the three locations in order to get around it when necessary.
