I have Databridge 234 and DataAssistSearch Wizard.
Thread begun 1/07/2019 9:21 am by john70964 | Last modified 1/09/2019 8:44 am by Ray Borduin | 2994 views | 6 replies |
john70964
I have Databridge 234 installed and am using DataAssistSearch Wizard. When I open DataAssistSearch Wizard I see this error message attached.
Is there a problem here please?
john
This looks like leftover debug code. You can just ignore it and click OK. I think if you reinstalled the extension it would go away.
john70964
Thanks Ray,
I have downloaded the later version and that message has disappeared.
I am now getting another error message I have attached.
After completion of the results and detail pages data assist gets stuck at Generating table.
Many thanks
John
That error implies that your database connection isn't working properly. Are you able to test the connection in Dreamweaver?
john70964
Yes Ray
Test connection
Message box says:
Connection was made successfully.
Later
I have now managed to get the process completed but am getting a syntax error.
A search on Hardy Shetland Bayliner should produce a result.
I have placed the url of the search page for you to have a look at the pages in a pm
Somehow your recordset is missing the table name. On line 12 you have:
$WADA->setQuery("SELECT id, Image1_250, Model, DescriptionShort, Price FROM ");
There should be a table name after the FROM. It appears the detail page has the same problem. I'm not sure how that occurred, but you can fix it by just adding the correct table name in after the FROM statement on both pages.
john70964
Thanks Ray
I cannot think where this went wrong, not only was there no table but $WADA->setQuery("SELECT id, should have been $WADA->setQuery("SELECT RecNo,
All seems OK now and the only difference I can see is when I re-created the initial recordset I included all fields.
Regards
John
