multiple update
Thread begun 1/04/2019 7:19 am by Sweens | Last modified 1/03/2020 10:37 am by Ray Borduin | 4144 views | 16 replies |
Sweens
multiple update
Hi Ray
I continue to have problems updating from mysql to mysqli multiple updates. I have reinstalled DA to ensure it's the current version, but no difference.
The repeat region displays the records properly, but I get the following error after pressing the update button.
Fatal error: Uncaught Error: Call to undefined function mysql_select_db() in /home/sites/sweens.uk/public_html/admin/modals/modal-mainpages-sort.php:65 Stack trace: #0 {main} thrown in /home/sites/sweens.uk/public_html/admin/modals/modal-mainpages-sort.php on line 65
Page attached.
When applying the multiple update, the following line was added, which I think is wrong, as it relates to the field being updated, not to the id of the record
<input type="hidden" name="sOrder_wamultihidden_<?php echo $RepeatSelectionCounter_1; ?>" id="sOrder_wamultihidden_<?php echo $RepeatSelectionCounter_1; ?>" value="1" />
The correct value should be, I think,
<input type="hidden" name="WADA_RepeatID_pg_id_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_pg_id_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo($rsPages->getColumnVal("pg_id")); ?>" />
(I've tried it with both values, and neither work).
I'm using PHP v 7.2, if that's relevant
Many thanks
Chris
This page has the MySQL version of the Multiple Update server behavior, not the MySQLi version. Open it up from the server behaviors window and reapply it with the MySQLi connection selected and the code should be updated automatically... assuming you have Databridge v2 installed.
Sweens
Thanks Ray
I think it might be my misunderstanding of the extension; I have the mysqli server extension pack, which I thought was now unnecessary as the facilities are now available in DataAssist - so I used the 'repeat selection' and 'multiple update' links from the webassists|DataAssist menu
I've reapplied everything, using the links from the webassist|MySQLi
I now get the following error:
Fatal error: Uncaught Error: Class 'WA_MySQLi_Query' not found in /home/sites/sweens.uk/public_html/admin/modals/modal-mainpages-sort.php:16 Stack trace: #0 {main} thrown in /home/sites/sweens.uk/public_html/admin/modals/modal-mainpages-sort.php on line 16
Updated page attached.
Chris
Sweens
I have sussed it!
The update beahaviour was inserted before the line
<?php require_once('../../webassist/mysqli/queryobj.php'); ?>
I moved this line above, and it now works properly.
Hope this helps for any future updates.
Cheers
Chris
Sweens
Hi Ray
Similar problems on another page, despite rebuilding it several times. I get the following error after trying to update multiple records
.../adminsection/members/committee-pages_Slideshow47.php on line 128
Chris
It looks like you have a standard MySQL multiple update server behavior instead of the MySQLi version. It appears your connection is MySQLi, so the multiple update should be the MySQLi version of the server behavior.
If you gave me FTP access and a URL with steps to reproduce the issue then I could debug further and help you get it fixed.
Sweens
Thanks Ray
I've applied the mysql_i version (I thought it would do this automatically on updating everything else - my bad!). Now I get
Fatal error: Call to a member function getColumnVal() on a non-object in /home/rotaryribi/public_html/adminsection/members/committee-pages_Slideshow47.php on line 15
line 15 is the redirect location:
$MultipleUpdateRedirect = "committee-pages_Slideshow.php?CtteeID=".$rsCtteePages->getColumnVal("ClubCtteeID") ."&PgID=".$rsPg->getColumnVal("PgID") ."";
Is the syntax wrong?
Unfortunately, I can't give you to access to this site.
Chris
It looks like the update code may have been placed higher on the page than the Recordset you refer to on that line... you probably just have to move it lower with copy/paste.
Sweens
Thanks Ray - that was the case; no error on pressing update - but no recirds are updated!
Latest version attached.
Cgris
It looks like it left behind the old syntax for naming form elements. Do a find and replace
search for: $RepeatSelectionCounter_1
replace with: $wa_repeatcount
The repeated variable name changed in MySQLi
