DataAssist - Required Fields
Thread begun 1/03/2019 9:55 am by dhagood355349 | Last modified 1/03/2019 10:51 am by Ray Borduin | 1551 views | 3 replies |
dhagood355349
Create Search and Results file with DataAssist and mark a couple of fields to be Required fields. When the files are created, the fields are not required and the search will run even with no data entered in any of the fields. Am I missing something or is this a bug?
Required fields are only created for Insert and Update pages. They aren't required for search pages. You can manually add form validation to make the form fields required on a search page.
dhagood355349
it allows you to set required for Search, which it should so you can control simple searches. It does insert the lines, I had to set them all to true for it to work correctly.
Lines it Created:
$WAFV_Errors .= WAValidateZC((isset($_GET["Zip"])?$_GET["Zip"]:"") . "",false,true,true,true,true,1);
$WAFV_Errors .= WAValidateEM((isset($_GET["Email"])?$_GET["Email"]:"") . "",false,2);
Changed all to "true"
$WAFV_Errors .= WAValidateZC((isset($_GET["Zip"])?$_GET["Zip"]:"") . "",true,true,true,true,true,1);
$WAFV_Errors .= WAValidateEM((isset($_GET["Email"])?$_GET["Email"]:"") . "",true,2);
Yes. It validates the syntax but doesn't make them required. The 'true' is the required attribute, so changing that will make it required. You could have opened the Server Validations server behavior and checked the "required" checkbox for the same effect.
You may also want to add the "required" attribute to the form fields themselves so that client validation will work as well.
