recorset broken
Thread begun 1/03/2019 9:39 am by Jamie | Last modified 1/05/2019 1:09 pm by Ray Borduin | 2234 views | 4 replies |
Jamie
recorset broken
Hey Ray
Am not sure if this got 'broken' from the other aspects we did on Moonraker but this recordset is now not returning any results and it should be showing 5 items that are in the same category as the product page that it is on
$MayLike = new WA_MySQLi_RS("MayLike",$DBConnection,5);
$MayLike->setQuery("SELECT productcategories.CategoryName, productcategories.CatPermalink, productcategories_2.CategoryName AS parentcategoryname, productcategories_2.CatPermalink AS parentpermalink, products.*, productmanufacturers.ManufacturerName, productmanufacturers.ManufacturerImage, productmanufacturers.ManufacturerDescription, productmanufacturers.ManPermalink FROM productcategories INNER JOIN productcategories AS productcategories_2 ON productcategories.CategoryParentID = productcategories_2.CategoryID LEFT OUTER JOIN products ON productcategories.CategoryID = products.ProductCategoryID INNER JOIN productmanufacturers ON products.ProductManufacturerID = productmanufacturers.ManufacturerID WHERE productcategories.CategoryID = ? AND products.ProductLive = 1 AND products.ProductID <> ? ORDER BY Rand()");
$MayLike->bindParam("s", "".$Categories->GetColumnVal("CategoryID") ."", "-1"); //WAQB_Param1
$MayLike->bindParam("s", "".$Categories->GetColumnVal("ProductID") ."", "-1"); //WAQB_Param1
$MayLike->execute();
The issue doesn't appear to be with this recordset. Maybe the issue is with the repeat region that displays it or the Categories recordset that is used to filter the results.
Jamie
Not sure if you saw my reply to your Skype convo but I think its the 'remaininginventory' that is breaking it as when I put it back up with that in the select it stops it from working but if I use the one with your rs then I lose the 'remaining stock'.
its also stopped an image showing for the manufacturer logo on line 329
have put my version back up so you can see.... and it definitely isnt showing the 'MayLike' results either
I added the stock column to the old SQL statement and that seems to have fixed it. I noticed that the SQL statement had changed dramatically other than just the stock being added in your updated version.
Jamie
thanks mate
