Show an inclusive tax
Thread began 9/10/2009 6:13 pm by timespider372434 | Last modified 9/15/2009 4:31 pm by Jason Byrnes | 3919 views | 12 replies |
timespider372434
Hello, could someone direct me on how to show a tax of 12.5% that is already included in the product price, it can be on the total not on each item. Here in New Zealand we have a tax on all goods called GST that is 12.5%
EXAMPLE: $100 total
The gst on this is $12.50
How do I show this $12.50 without adding it to the $100
Thanks for any help
In the cart object, create a new calculation named "GST" as:
([Price] * [Quantity]) * 0.125
Where you want to display this, add:
<?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->TotalColumn("GST")); ?>
where "$eCart1" is the name of your cart
timespider372434
Thanks Jason
You're welcome.
timespider372434
Trouble showing GST
Hi, I'm still having trouble showing the gst(the tax in my first post).
I have uploaded a zipped folder with a screen shot of the calculation & one of the code in the view cart where I think it should be. Could you elaborate on what I'm doing wrong. In the screen shot my cart is called '$cartOnlineMC' & the code is highlighted where I'm trying to show it.
eCartCalc.zip
Are any of the tax rules showing?
You have placed the code in a region of the page that will only be displayed if there is a rule from the tax tab that is showing.
timespider372434
Getting There
Hi Jason, I have moved the code out of this area & presto the gst is showing. But is there a way to show this as a tax? I have no other tax rules as I don't require them. Sorry that I'm sounding like such a beginner but I'm just getting used to eCart & finding my way in the dark, & I have been reading the pdf files but finding it a little confusing.
Again thanks for the help. Chris
Sure, you could create a rule on the tax tab so it is displayed.
Use the trigger:
subtotal For Any Column:
if the subtotal of column "GST" is ">" a value of "0"
and the calculation:
based on column Subtotal:
Subtotal of Column "GST" "Plus" "0"
timespider372434
Do I keep the gst calculation I added earlier(I have) as when I get to the last bit in tax area that you said to do
"and the calculation:
Subtotal of Column "GST" "Plus" "0""
GST doesn't exist in the dropdown menu yet it does exist in the first dropdown menu.
timespider372434
My brain is a gloopy mess
I have changed the calculation
From "GST" as: ([Price] * [Quantity]) * 0.125
To "GST" as: ([Price] * [Quantity]) /9
as it was adding the gst to the total & 12.5% works out to be a ninth when inclusive.
But as I said above the GST only shows in the condition area dropdown menu & doesn't show in the calculation area dropdown menu.
So I have used "Based on column subtotal" 'subtotal of column' "price" - it now shows the GST correctly(well sort of) but the total price now shows double the amount in my page.
For example it shows. One item subtotal of $19.95 then GST of $2.22 this is correct
then the total is $39.90 which is double & incorrect.
Any other ideas?
Chris
