HTML Editor's File Manager Error
Thread begun 12/31/2018 10:46 am by randyrie405335 | Last modified 1/05/2019 2:00 pm by Ray Borduin | 1637 views | 5 replies |
randyrie405335
When I try to upload images, I get this error: (see 'Warning.png' attached) althought the file successfully uploads. Is there something I should change on line 654 (see 'Line 654.png' attached)?
This should be updated in the latest version of the extension as of a few months ago. You can manually update that line to:
if ($overwrite && is_file($thumb)) unlink($thumb);
But you may want to reinstall to make sure you don't have to make this change when using it in the future.
randyrie405335
I updated to v234 but don't see the new code on line 654. Should I add it or is it located somewhere else in the uploader.php file? (See my attachment)
That line should be updated any time you add a new editor. It may require you to delete the old webassist/ckeditor folder and re-apply.
You can manually add it if that doesn't work.
randyrie405335
OK... I created a dummy site and applied webassist features to a test page so the WebAssist folder builds all the feature folders (e.g., ckfinder). I notice that line 654 has the updated code. I dragged the ckfinder folder from the dummy site to my new, real site. I'll let you konw if I have any more issues with the 'unlink/uploads' warning.
Thanks for bringing this to my attention. There was a missing include file in the config.php file. I've updated the extension to address this issue.
