Colname not working
Thread begun 12/28/2018 3:51 am by john70964 | Last modified 1/04/2019 2:25 pm by Ray Borduin | 3567 views | 8 replies |
john70964
Colname not working
Hello Ray
I have a simple list and details page.
The list seems OK and when I hover over a record number the url shows
correctly at the bottom right hand of the page.
However when I click the link to the details page
I get the correct url http://localhost/boatsforsalenow_mysqli/categories/details.php?11791=11791 but the page remains blank.
Have you an idea why this could be?
John
List.php
<?php require_once('../Connections/conn1_i.php'); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
$rsCanalBoatList = new WA_MySQLi_RS("rsCanalBoatList",$conn1_i,0);
$rsCanalBoatList->setQuery("SELECT RecNo, Manufacturer, Model, Image1_250 FROM boats WHERE Category1 = 'Canal Boats'");
$rsCanalBoatList->execute();
<head>
</head>
<body>
<p>List Canal Boats </p>
$wa_startindex = 0;
while(!$rsCanalBoatList->atEnd()) {
$wa_startindex = $rsCanalBoatList->Index;
<p><a href="details.php?<?php echo($rsCanalBoatList->getColumnVal("RecNo")); ?>=<?php echo($rsCanalBoatList->getColumnVal("RecNo")); ?>"><?php echo($rsCanalBoatList->getColumnVal("RecNo")); ?></a><?php echo($rsCanalBoatList->getColumnVal("Manufacturer")); ?><?php echo($rsCanalBoatList->getColumnVal("Model")); ?><a href="details.php"><img src="../BoatImages/<?php echo($rsCanalBoatList->getColumnVal("Image1_250")); ?>" alt="Canal Boats" /></a></p>
$rsCanalBoatList->moveNext();
$rsCanalBoatList->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
</body>
</html>
Details.php
$rsCanalBoatDetails = new WA_MySQLi_RS("rsCanalBoatDetails",$conn1_i,100);
$rsCanalBoatDetails->setQuery("SELECT boats.RecNo, boats.RegDate, boats.Company, boats.Manufacturer, boats.Model, boats.BuildDate, boats.NeworUsed, boats.Category1, boats.HullMaterial, boats.`Engines`, boats.LOA, boats.image1_900 FROM boats WHERE boats.RecNo = ?");
$rsCanalBoatDetails->bindParam("i", "".($rsCanalBoatDetails->getColumnVal("RecNo")) ."", "-1"); //WAQB_Param1
$rsCanalBoatDetails->execute();
<head>
</head>
<body>
<p>Details <br />
<?php echo($rsCanalBoatDetails->getColumnVal("RecNo")); ?><br />
<?php echo($rsCanalBoatDetails->getColumnVal("Manufacturer")); ?><br />
<?php echo($rsCanalBoatDetails->getColumnVal("Model")); ?><br />
<?php echo($rsCanalBoatDetails->getColumnVal("BuildDate")); ?></p>
</body>
</html>
The URL should probably be something like:
http://localhost/boatsforsalenow_mysqli/categories/details.php?RecNo=11791
Then on the details page this line:
should probably be:
$rsCanalBoatDetails->bindParam("i", "".($_GET("RecNo")) ."", "-1"); //WAQB_Param1
You can't refer to a recordset value in a parameter for the recordset that you are creating. I think you want to use the passed in value from the url instead.
john70964
Hello Ray
In the past i have created many links but at the moment I do not seem able.
This seems to have occoured after updating to DB 234, I must now be making some basic mistakes.
Is ther a tutorial anywhere for this. I found one of JB's but it was many yearsold now and out of date.
To try to understand where I am going wrong I copied my steps.
I create a link on the list.php named Details
Link box shows details.php
On the right hand side Of the link box there is a folder.
I select the folder and use the Data Sources tab to select RecNo
This produces code on the list.php page of
<a href="<?php echo($rsCanalBoatList->getColumnVal("RecNo")); ?>">Details</a>
It appears the target of page Details.php is missing.
When I hover over the link I see http://localhost/boatsforsalenow_mysqli/categories/119898
I can correct this by inserting detail.php
reating <a href="details.php<?php echo($rsCanalBoatList->getColumnVal("RecNo")); ?>">Details</a>
which arrives at the correct page.
On the details.php page I deleted the recordset to insert a new one.
I selected Query builder (which seems very slow) and dragged the boats table
I select the few column names required.
After this I selected Advanced Builder
I selected Where RecNo comparison value is set to URL Parameter and I entered RecNo in the box and OK.
On the page this brought up a syntax error on line 4
I deleted the recordset and reset the page
I created a new recordset rsDetails in Simple format
with RecNo Url Parameter and RecNo
I then selected Advanced
I selected Edit in the Variables Column whci showed
Colname Interger -1 $_GET['RecNo'] I selected OK and OK again
When I ran the pages
The url shows on the List page appears to be correct and when I press the link
the url shows as http://localhost/boatsforsalenow_mysqli/categories/details.php11898
which is also correct
But I get the error
Object not found!
The requested URL was not found on this server. The link on the referring page seems to be wrong or outdated.
Please inform the author of that page about the error.
If you think this is a server error, please contact the webmaster.
Error 404
localhost
Apache/2.4.29 (Win32) OpenSSL/1.0.2l PHP/5.6.32
I have placed the files at
http://net100test.co.uk/WA_DB234/BFSN_full/categories/list.php
ftp detail
Ftp Detail
Server: home415519235.1and1-data.host
Port: 22
Protocol: SFTP
User name u68925687-Mysqli_tes
Password P0lyg0n&20*&
I think when I get clear on the system of getting the links to work
I will publish the method on the forum to help me if ever I get into a pckle again.
(If that is Ok)
Instead of:
it should be:
<a href="details.php?RecNo=<?php echo($rsCanalBoatList->getColumnVal("RecNo")); ?>">Details</a>
john70964
Hello Ray
I replaced the code but it came up with a syntax error and it seems the server behaviour is missing,
I attach an image
You replaced the wrong line of code. The line I was telling you to replace was on the results page, not the details page, and it should be in the <html> nested in the repeat region, not in the recordset code on the top of the page.
john70964
Thanks Ray
I have the List Page producing the url
localhost/boatsforsalenow_mysqli/categories/details.php?RecNo=11476
from the Details link on List.php
When the Details link is used it opens details.php but no records appear.
When the Recordset for the details.php is tested
with a RecNo inserted eg 11746 the correct detail appears.
I hope I have explained this OK for you.
The code for detail.php is below
$rsDetails = new WA_MySQLi_RS("rsDetails",$conn1_i,1);
$rsDetails->setQuery("SELECT RecNo, Manufacturer, Model, Category1, image1_900, Image1_250 FROM boats WHERE RecNo = ?");
$rsDetails->bindParam("i", "".(isset($_GET['".($rsDetails->getColumnVal("RecNo")) ."'])?$_GET['".($rsDetails->getColumnVal("RecNo")) ."']:"") ."", "-1"); //colname
$rsDetails->execute();
<head>
</head>
<body>
<p>Details <br />
<?php echo($rsDetails->getColumnVal("RecNo")); ?><br />
<?php echo($rsDetails->getColumnVal("Manufacturer")); ?><br />
<?php echo($rsDetails->getColumnVal("Model")); ?><br />
<?php echo($rsDetails->getColumnVal("BuildDate")); ?></p>
</body>
</html>
This line:
should be:
$rsDetails->bindParam("i", "".(isset($_GET["RecNo"])?$_GET["RecNo"]:"") ."", "-1");
john70964
Thank you Ray
