Sites no longer work with php7
Thread begun 12/26/2018 12:16 pm by Peterson Design Studio - jefferis | Last modified 12/31/2018 11:24 am by Ray Borduin | 1917 views | 3 replies |
what is broken?
Thanks Ray. I was able to php 5 installed for now, but I'm finding that the javascript pop up window is no longer transferring the data to the window. It is supposed to display a larger image than the thumbnail upon click. This is the code in the catalog page:
<p align="center"><a href="#" onclick="MM_openBrWindow('<?php echo "show_image.php?img={$row_viewall['pictures']}"; $img = $row_viewall['pictures'];?>','','toolbar=yes,scrollbars=yes,resizable=yes,width=550,height=500');return false">
<img src='http://yellow-diamonds.com/<?php echo $row_viewall['thumbnail']; ?>' alt="<?php echo $row_viewall['item_name']; ?>" border="0" /></a><br />
<span class="under"><?php echo $row_viewall['item']; ?></span>
***** Where pictures is the field for the larger image the thumbnail is what it says. I'll paste the popup window code below. Would appreciate if you can help me figure out what is no longer allowed. It used to work just fine.
Old MySQL code will not work with php7. Your best solution will be to downgrade php versions to v6 or below.
You could also update your pages to mySQLi with Data Bridge v2 or re-create them with MySQLi Server Behaviors. That would be a rather large project if you have lots of sites with lots of pages that need to be addressed, so I'd probably look into finding a server that supports mysql in the meantime even if you go down that route.
can you auto update?
Does Data Bridge v2 have a simple means of updating existing webassist sites in DW to new mysqli compatibility.
It includes migration functionality that can be applied page by page. It won't migrate an entire site at once.
You just have to create a mySQLi connection and then open up any server behaviors that use a standard mySQL connection and choose the new MySQLi connection. Then when you click "ok" all of the code associated with that server behavior will be migrated.
