Nested repeat regions, use value from parent repeat region to filter nested
Thread begun 12/24/2018 11:15 am by p.kelembeck232519 | Last modified 9/17/2019 3:33 pm by Ray Borduin | 4872 views | 26 replies |
p.kelembeck232519
I have managed to nest a repeat region within a parent repeat region but I am struggling to get a parent column value to the nested region so I can filter.
I have tried to generate a variable using 'Add Variable' but on creating a variable with this I get the error message '$client_id is an invalid variable name; it does not appear in the SQL'. If this isn't the correct way to generate a variable to share between parent region and nested region please let me know.
If it is the correct way what am I doing wrong? Thank for your help (I have attached present code)
You didn't attach any files.
The parameter name shouldn't have any special characters in the SQL statement.
Try using "clientid" as the parameter.
p.kelembeck232519
Nested repeat regions, variable......., solved but now I'm getting duplicate values in nested results.
Hi Ray, thanks very much for getting back to me in the holiday period. I did attempt your suggestion but got the same error. I solved the issue though by creating a variable manually e.g.
$clientid = ($RsTest->getColumnVal("id"));
settype($clientid, "integer");
Then I placed variable $clientid in the query of the record set for the nested repeat region.
The problem I have now is that I am getting duplicate results in the nested repeat region. I am not the greatest coder in the world but I presume it's because I am using two different record sets and two different repeaters. And the nested repeat region is forced to loop again per parent record.
So my question now is, is there a simple command I can place here to spot and cancel/kill duplicates?
or
Should I use a join tables in one record set to unify the tables in one query? I have read that this solves the duplicate problem in the forums?
Please let me know what you think.
Many thanks.
I have attached updated code if you need to view.
Here is an updated version of your page built with the extensions without hand coding to show you what I was referring to.
What duplicated results are you getting? The fmid shouldn't be duplicated, is it? I'm not sure why it wasn't working properly. It appeared to me that it should have been working as you had it, but look at the page I have attached and provide more detail about what is being repeated that shouldn't be. Maybe include a URL where I can see the problem so I can understand it better.
p.kelembeck232519
Thanks Ray, I see what you mean. I should've created the variable in the query before attempting to use add variable.
Here is the duplication error example:
https://www.appsevo.com/Filemaker-Email-Campaigns/test.php
The duplicates are happening on the nested repeat region (under the heading 'Colours'). I still don't know why.
This is the same file you sent back.
Please let me know what you think. Thanks
You could probably just update your SQL statement from:
$nested->setQuery("SELECT * FROM test_repeat, fm_emails_est_tsk_client WHERE test_repeat.fmid = ?");
$nested->setQuery("SELECT * FROM test_repeat WHERE test_repeat.fmid = ?");
You should already have the values from the fm_emails_est_tsk_client table in the other recordset, so it doesn't need to be added to this one.
p.kelembeck232519
Great!!! Thanks Ray.
That worked perfectly.
JBWebWorks
I think my problem relates to this post so here is my question.
I have a photos page and photos categories and I want the photos categories to repeat and under each categories are images in that category. And I want the images to repeat.
My code for the two recordsets
$Recordset1 = new WA_MySQLi_RS("Recordset1",$connsqli,0);
$Recordset1->setQuery("SELECT * FROM photos_category, photos WHERE photos.photos_category = photos_category.category_name ORDER BY photos_category.category_name");
$Recordset1->execute();
$Recordset2 = new WA_MySQLi_RS("Recordset2",$connsqli,0);
$Recordset2->setQuery("SELECT * FROM photos WHERE photos.photos_category = ?");
$Recordset2->bindParam("s", "".($Recordset1->getColumnVal("category_name")) ."", "-1"); //var1
$Recordset2->execute();
And the code for the repeat regions
$wa_startindex = 0;
while(!$Recordset1->atEnd()) {
$wa_startindex = $Recordset1->Index;
<span class="category"><?php echo($Recordset1->getColumnVal("category_name")); ?></span><br />
<br />
$wa_startindex = 0;
while(!$Recordset2->atEnd()) {
$wa_startindex = $Recordset2->Index;
<div align="center"><a href="photos/<?php echo($Recordset2->getColumnVal('photos_file')); ?>" rel="lightbox" title="<?php echo($Recordset2->getColumnVal("photos_alt")); ?>"><img src="photos/<?php echo($Recordset2->getColumnVal("photos_file")); ?>" /></a></div>
$Recordset2->moveNext();
$Recordset2->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
$Recordset1->moveNext();
$Recordset1->moveFirst(); //return RS to first record
This only shows the repeat from Recordset1 for any category that has images but the images do not repeat and the only image shown is in multiple categories?
Help Please.
Dave BuchholzBeta Tester
$recordset2 needs to be placed inside the loop like so for your code to work
$wa_startindex = 0;
<br />
$wa_startindex = 0;
JBWebWorks
Thanks Dave,
It is working but it is repeating the region the number of times that there are images in the database. So if category one has four images, it repeats four times, etc.
I have two tables in db.
photos_category with two cols - category_ID and category_name
photos with four cols -photos_ID photos_file photos_alt and cat_ID
$Recordset1->setQuery("SELECT photos.photos_ID, photos.photos_file, photos.photos_alt, photos.cat_ID, photos_category.category_ID, photos_category.category_name FROM photos, photos_category WHERE photos_category.category_ID = photos.cat_ID ");
And the loop
$wa_startindex = 0;
$Recordset2->setQuery("SELECT * FROM photos WHERE photos.cat_ID = ? ORDER BY photos.photos_ID");
$Recordset2->bindParam("i", "".($Recordset1->getColumnVal("category_ID")) ."", "-1"); //var1
<br />
$wa_startindex = 0;
</div>
