DA results page paging keeps adding more results
Thread begun 12/23/2018 4:25 pm by mrs | Last modified 1/03/2019 8:24 am by Ray Borduin | 1410 views | 3 replies |
mrs
I noticed as I was paging through my results page (created by DA) that the same record kept appearing at the top of the list, This made me investigate and I realised that more records were printing at the bottom of the repeat region of the table as I clicked further through the records, So I tested other results pages I had created using DA, and the same thing is happening.
Basically, on the first page I have the first 20 records returned. As I page through to the second page of results the suffix of '?pageNum_WADAtbl_product=2&totalRows_WADAtbl_product=158' is added to the url after the ,php and the second lot of results is returned as expected, but clicking through to the third page of results doesn't remove the previous (second) set of records. As I click through to the fourth page, both the second and third lot of records are kept and the list just keeps growing until I run of records. The last page has hundreds of rows returned. Have a look here:
http://brandchampion.co.uk/test_product_results.php This is straight out of DA, unedited.
http://brandchampion.co.uk/rental-furniture.php and this is the live version which I have edited, but it doing that same behaviour.
I've attached three pages in question.
Ordinarily, this works perfectly, so what's gone wrong?
I think there was an issue with a previous version of webassist/mysqli/rsobj.php. I've attached a newer version which is included in the latest update (reinstall to make sure you use it in future applications of the extension)
Please test and let me know if updating this file fixes the problem. If it doesn't I'll need FTP access and a url to reproduce the issue and debug it.
mrs
Yes, that seemed to work fine for me. Thanks Ray
I did have a version of that file that was 2.6. The one I have just downloaded is 2.23. Is 2.23 the latest version then?
Yes that is the latest. It gets updates whenever the extension is updated. I suggest checking back once per month or so and install the latest version. However, if you aren't running into any problems then it really isn't necessary. I often add new features and fix any issues reported through the forums. As the extension and code matures the updates will become less frequent.
