Keep Getting error when creating Dataassist pages
Thread begun 12/22/2018 7:11 am by willo009412397 | Last modified 12/26/2018 12:56 pm by Ray Borduin | 1509 views | 3 replies |
willo009412397
I keep gettting the below Error when running DataBridge v2 Dataassist pages, im using Dreamweaver CS 5.5 - and i have had everything working in the past.
Ive tried re-installing nothing seems to work pls help. My Error is below
"c:\Users\MyName\AppData\Roaming\Adobe\DreamweaverCS5.5\en_us\Configuration\Floaters\WA_sitetools\ProgressV2.js" Col has no properties....
I will attach a copy of the above page also, Thankyou for any help
This error implies an issue with connecting to your database to get column information. I'd probably need to do a screen share in order to debug it with you. If you post a US phone number or Skype contact information then I can call you to look into it with you directly and get it running again.
willo009412397
Thanks for the reply, would it have something to do with me using my own database? i had the older version on Dataassist when creating the pages you could Delete columns that you didnt require. But using it through Databridge there does not seem to be the option to cancel un-wanted columns. Not on the Results or Details pages anyway.
Yes you can... you just have to click the page and edit it and then you can add or remove columns.
I imagine it has something to do with the columns you have specified not existing in your database, or your database connection not working in general.
