Server Validation wiping form field data, despite having value set to ValidatedField and Recordset value?
Thread begun 12/21/2018 5:27 am by Nathon Jones Web Design | Last modified 12/26/2018 11:54 am by Ray Borduin | 937 views | 2 replies |
http://www.sportsmedicalcertificates.com/health-screening-form.php?tab1=1
If you complete Step 1 in the above form, it saves to database as an INSERT. Every other Step, 2-5, is then an UPDATE.
I have different Server Validations for each Step.
If you complete Step 1 you are taken to Step 2 by default. However, if at that stage you decide to complete Step 4 and the validation at Step 4 fails, it is wiping all of the values from all of the other form fields. Try selecting "Yes" for one of the questions in Step 4 but then not entering any information in the textarea below. ...then, when the validation fails, click on the Step 1 tab.
Yet, all of the fields in Step 1 have the following value (this is the FirstName field):
value="<?php echo(isset($_GET['v'])?ValidatedField("healthscreeningform_984","FirstName"):$rsEDITFORM->getColumnVal("SMCformFIRST")) ?>"
Why is this happening?
FTP details provided below.
Thank you.
NJ
FTP...
That is because you are using the same URL parameter for each validation check. The issue is that only one validation failed but all of the forms try to populate from the failed validation fields, but they aren't all saved since they are separate validations.
The best solution is probably to use a different url parameter for the failed redirect for each tab and then you can check for it when displaying the form like:
value="<?php echo(isset($_GET['v1'])?ValidatedField("healthscreeningform_984","FirstName"):$rsEDITFORM->getColumnVal("SMCformFIRST")) ?>"
and
value="<?php echo(isset($_GET['v2'])?ValidatedField("healthscreeningform_984","LastName"):$rsEDITFORM->getColumnVal("SMCformLAST")) ?>"
