notification email
Thread begun 12/19/2018 5:18 am by Jamie | Last modified 12/21/2018 11:28 am by Ray Borduin | 2063 views | 5 replies |
Jamie
notification email
I have a site that takes sign ups from customers but requires authorisation from my client. At the moment, a verification email is being sent to the customer and presently have bcc's the client in on this email to give them the heads up that there is a new sign up that they will need to action.
The problem is that bcc ing in the client to the verification email gives the client the verification URL path which, if they accidentally click it will stop it from being used by the customer.
How woudl I go about setting up an email that gets pinged to my client with the date, name and email address of the new sign up rather than getting the verification email?
Jamie
You would just set up the page with two email server behaviors so that the client can have a different body.
Jamie
Thanks Ray. Have been trying to do that and am getting this error after trying to insert a new 'Send Email' behaviour: http://prntscr.com/lx3t7w and nothing is getting inserted
Have tried it on a couple of pages with an email send on them and the same pop up
Make sure you remove the redirect from the first email so that the second can send. This is true for whenever you have multiple server behaviors that run from the same trigger... only the last one in the list should have a redirect set.
Jamie
thanks Ray all working now
am passing some identifying info to the email and was wondering if its ok to combine
@session_start();
if(($_SERVER["REQUEST_METHOD"] === "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) {
$_SESSION["Company"] = "".((isset($_POST["Company"]))?$_POST["Company"]:"") ."";
@session_start();
$_SESSION["Email_Address"] = "".((isset($_POST["Email_Address"]))?$_POST["Email_Address"]:"") ."";
@session_start();
$_SESSION["Last_Name"] = "".((isset($_POST["Last_Name"]))?$_POST["Last_Name"]:"") ."";
@session_start();
$_SESSION["First_name"] = "".((isset($_POST["First_Name"]))?$_POST["First_Name"]:"") ."";
into one
@session_start();
Yes. That is fine to do, and I'd probably do the same.
