Deprecated code errors!
Thread begun 12/17/2018 6:51 am by Wenchofkrf | Last modified 12/17/2018 11:12 am by Ray Borduin | 3786 views | 9 replies |
Wenchofkrf
Help! Our host service did a php upgrade, and now I have "deprecated code" errors on every page!
this is one of the pages, and the attachment is the code.
http://starfireswords.com/products/steel/ld4.php
These are just warnings that won't effect the overall functionality of the page.
If you receive errors regarding function deprecation, the following two methods can tell PHP to simply stop mentioning deprecated functions or coding:
You can add the following line to your php.ini file:
error_reporting = E_ALL & ~E_DEPRECATED & ~E_NOTICE
Or you can add the following line to any page that shows the message:
error_reporting
(E_ALL & ~E_DEPRECATED & ~E_NOTICE);
Wenchofkrf
Where in the code would I place this, on the pages? (As I don't seem to have an .ini page, at this point.)
You can contact your hosting provider about how to update your php.ini file to remove deprecated messages and I'm sure they can help.
You can add the php anywhere on the page above where the message occurs. The first line of code on the page would work.
Wenchofkrf
Thank you!
Wenchofkrf
Well, that got the pages working again, but...
One more problem, that did not occur before this blasted update:
When I try to add something to the cart, I get this error:
"Warning: Cannot modify header information - headers already sent by (output started at /home8/starfir3/public_html/products/steel/barb.php:3) in /home8/starfir3/public_html/products/steel/barb.php on line 99"
and a blank page. How do I make the cart active again?
There is probably a blank line on line 3 of barb.php. You probably just have to delete that. If you attached the page with the error I could be more certain in my diagnosis.
Wenchofkrf
It seems to be on each page
Your first three lines of code are:
error_reporting
?><br>
You can't have a <br> tag above the <html> tag. You just have to delete that.
Wenchofkrf
Thank you
