Errors The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead
Thread begun 12/15/2018 8:13 am by jo271221 | Last modified 12/16/2018 9:36 am by Ray Borduin | 538 views | 1 replies |
jo271221
I did find tickets related to this but none in the last year so I am wondering if it is still true that all of the code on all of the pages need to be adjusted before this warning will go away or if there is something in the connection file.
I intend to update the code soon so I would like to either continue to get the warnings or just temporarily turn them off until I can update the code.
Thank You!
You can turn off deprecated messages in your php.ini file. The code only needs to be updated if you move to PHP7.
You should be able to adjust the setting in your hosting control panel or php.ini file directly if you have access to it and turn off deprecated messages in the php.ini file like:
error_reporting = E_ALL & ~E_DEPRECATED & ~E_NOTICE
Or you may add the following line to the top of any page that has the message:
error_reporting
(E_ALL & ~E_DEPRECATED & ~E_NOTICE);
