Recordset error when listing all fields in table in the SELECT statement?
Thread began 12/15/2018 5:34 am by Nathon Jones Web Design | Last modified 12/16/2018 11:50 am by Ray Borduin | 212 views | 1 replies |
When I use this:
$rsSANDBOXPRODUCTS = new WA_MySQLi_RS("rsSANDBOXPRODUCTS",$csdbmysqli,0);
$rsSANDBOXPRODUCTS->setQuery("SELECT * FROM Items_FromSandBoxFeed");
$rsSANDBOXPRODUCTS->execute();
..the recordset works. When I use this:
$rsSANDBOXPRODUCTS->setQuery("SELECT ItemId, Title, ImageUrl, Category, CategoryId, BuyingOptions, SellerUsername, SellerFeedbackPercentage, SellerFeedbackScore, GTIN, Brand, MPN, EPID, ConditionId, Condition, PriceValue, PriceCurrency, PrimaryItemGroupId, PrimaryItemGroupType, ItemEndDate, SellerItemRevision, ItemLocationCountry, LocalizedAspects, SellerTrustLevel, Availability, ImageAlteringProhibited, EstimatedAvailableQuantity, AvailabilityThresholdType, AvailabilityThreshold, ReturnsAccepted, ReturnPeriodValue, ReturnPeriodUnit, RefundMethod, ReturnMethod, ReturnShippingCostPayer, RestockingFeePercentage, AcceptedPaymentMethods, DeliveryOptions, ShipToIncludedRegions, ShipToExcludedRegions, InferredEPID, InferredGTIN, InferredBrand, InferredMPN, InferredLocalizedAspects, AdditionalImageUrls, OriginalPriceValue, OriginalPriceCurrency, DiscountAmount, DiscountPercentage, EnergyEfficiencyClass FROM Items_FromSandBoxFeed");
...I get the following error:
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Condition, PriceValue, PriceCurrency, PrimaryItemGroupId, PrimaryItemGroupType, ' at line 1"
Any idea why?
Thank you.
NJ
What is the URL to the page. I don't see how that would cause an issue or the error would relate to the first SQL statement. I'll have to look at the page to determine what might be causing it.
