Mysqli Pagination
Thread begun 12/15/2018 4:02 am by Kumel | Last modified 1/03/2019 10:49 am by Ray Borduin | 4952 views | 14 replies |
Kumel
Mysqli Pagination link problem.
I have following code based on your tutorial on MYSQLI Numbered pagination:
$maxRows_Properties =4;
$Properties = new WA_MySQLi_RS("Properties",$con2,$maxRows_Properties);
$Properties->setQuery("SELECT * FROM Properties");
$Properties->execute();
$PropertiesTotal = new WA_MySQLi_RS("PropertiesTotal",$con2);
$PropertiesTotal->setQuery("SELECT count(1) a FROM Properties");
$PropertiesTotal->execute();
$Properties_Total = (int)$PropertiesTotal->Results[0]['a'];
$Req_Pages = ceil($Properties_Total/$maxRows_Properties);
$totalRows_Properties = $Properties_Total;
$pageNum_Properties = 0;
if (isset($_GET['page'])) {
$pageNum_Properties = $_GET['page'];
$incdone = false;
if ($maxRows_Properties == 0)
$maxRows_Properties =1;
$incdone = true;
$totalPages_Properties = ceil($totalRows_Properties/$maxRows_Properties)-1;
if($totalPages_Properties > 0 && !$incdone )
$elems = array();
for ($i=0;$i<$Req_Pages;$i++)
if ($i==$pageNum_Properties)
$elems[] = "<li><a class=\"current-page\" href=\"properties.php?page=$i\">".($i+1)."</a></li>";
else
$elems[] = "<li><a href=\"properties.php?page=$i\">".($i+1)."</a></li>";
echo implode(" ",$elems);
I want to use properties.php?page=1 or 2 or 3 & so on rather than pageNum_Properties.
Numbering works. But results display ain't changing.
You can probably just add code to the top of the page (above the recordset) like:
if (isset($_GET["page"])) {
$_GET["pageNum_Properties"] = $_GET["page"];
Kumel
Seems to work. thanks.
Btw i have following sql for the Properties table
SELECT ....
FROM Properties INNER JOIN Units ON Units.UnitPropertyID = Properties.PID GROUP BY Properties.PID ORDER BY Units.UnitName ASC, Units.UnitSize ASC
And for PropertiesTotal when I use the above SQL, pagination is not visible.
this works & display pagination:
.. FROM Properties INNER JOIN Units ON Units.UnitPropertyID = Properties.PID  ORDER BY Units.UnitName ASC, Units.UnitSize ASC
Why is it so when i use GROUP IN SQL for Total it doesnt work.
I'd need to see the full SQL statement and describe what you are trying to achieve vs the result you are seeing to explain anything. Using GROUP will change the number of results. It shouldn't effect weather pagination works, but it would effect how many pages there are.
Maybe pagination isn't showing because there isn't more than one page.
Kumel
this sql is right. its used for repeating properties.
SELECT Properties.PID, Properties.PName, Properties.PArea, Properties.PCategory, Properties.PPricepsqft, Properties.PMainimage, Properties.PPosition, Units.*
Please provide a URL to reproduce the issue and FTP access and I can look into why the pagination doesn't work.
Kumel
I havent uploaded online uet.. Once done. will update the link here.
Kumel
Well i didn't want numbering system. hence fine with "next" "prev".
But i got a doubt.
<?php if ($Properties->PageNum > 0) { // Show if mysqli not first page ?>
<li style="padding:20px;"><a class="prev" href="<?php echo $Properties->getPrevPageLink(); ?>">Previous</a></li>
<?php } // Show if mysqli not first page ?>
<li><a class="next" href="<?php echo $Properties->getNextPageLink(); ?>">Next</a></li>
Now here default on using it works. i want the link to be seo friendly, so how to make link appear like page.php?page=1. Rather than page.php? pageNum_Properties=1 & so on.
I doubt it would make an SEO effect unless you think someone will be googling the term "page", but you could use str_replace() to replace the parameter in the url like:
<?php echo str_replace("pageNum_Properties=","page=",$Properties->getPrevPageLink()); ?>
Then on the top of the page change it back in the php above the recordset like:
if (isset($_GET["page"])) $_GET["pageNum_Properties"] = $_GET["page"];
Kumel
I m facing issues with pagination. PVT MSG.
