I cant find relational table within mysqli.
Thread begun 12/10/2018 11:06 am by Kumel | Last modified 1/04/2019 11:32 am by Ray Borduin | 3195 views | 7 replies |
Kumel
Is there no relational table available in mysqli?
Also i cant find multiple update option within mysqli
The MySQLi Server Behaviors only have the Server Behaviors that Dreamweaver had natively for MySQL. They don't include any of the ones webassist added for DataBridge.... those are available for MySQLi in the DataBridge v2 upgrade.
Web Manager
Can't find recordset I created in Query builder
I created a query and the coding for it is on the page but I can not find it when trying to select for a repeating table any idea as to why?
What steps should be followed when creating a Recordset using Databridge 2 to create a list for records to display ?
Can I see a copy of the page. Maybe you are mixing MySQL and MySQLi again? MySQLi recordsets use MySQLi repeat region and MySQL recordsets use the standard Repeat Region server behavior.
Web Manager
I realize both type on on this page
This is a standard recordset. What menu option are you choosing when you are trying to repeat values from it?
Web Manager
Webassist / database
You can get that error when Dreamweaver is unable to connect to the database. Try opening the recordset and Testing it to see if you can get results in Dreamweaver. The recordset must test properly before a repeated table can be added to the page.
