Incorrect Results
Thread begun 12/10/2018 6:29 am by vernon webb | Last modified 12/11/2018 11:53 am by anonymous | 2087 views | 4 replies |
vernon webb
Incorrect Results
Hey Ray,
You worked on this page and since the day I think you worked on it it hasn't been working using the user drop down (for example kmurtha shows only results from before 2018-10-29) and yet the company works fine (i.e. Braverman). It's a bit complicated this script and would hate to mess anything up.
I've never worked on this page... I didn't even have a local copy downloaded.
Anyway I guess that isn't the point... I've taken a look at the page and it does appear to show older files when I make the selection you specified.
I selected kmurtha and can scroll down and see records as far back as 2007.
vernon webb
Sorry it's the detailed results of that page you worked on, I got them confused. The point is when you submit using the user list you get only stuff dating before 10-29-2018 and no recent stuff. However the Braverman one I pointed out is from kmurtha but is from 12-07-2018 and shows up if you select Braverman from the company list and submit and not when you user the user list.
It looks like a data integrity issue. The projectclient value isn't being set for the recent inserts... that is why they aren't showing up, not because of a problem on this page.
I've added the client id value to the results to demonstrate the problem. You can see that the client ID for kmurtha is 37, but the client ID set for the two Braverman records are blank and 75. That is why they don't return in the first search.
vernon webb
Got it. Thanks
