Credit Card payments
Thread begun 12/07/2018 4:18 am by NWak04030229 | Last modified 12/16/2018 12:38 pm by Ray Borduin | 3550 views | 9 replies |
NWak04030229
My cart will accept all PayPal payments but if someone goes to the PayPal checkout and enters their own card details because they don't have a PayPal account then the page redirects to a page on my site saying the cart is empty and they are unable to complete the transaction
It should work the same either way. Most likely the issue is the return redirect using www. when your site doesn't or vice versa, not an issue with the type of payment.
The best solution is probably to either force www. or force not www. using an htaccess rule.
#Force www:
RewriteEngine on
RewriteCond %{HTTP_HOST} ^example.com [NC]
RewriteRule ^(.*)$ http://www.example.com/$1 [L,R=301,NC]
#Force non-www:
RewriteEngine on
RewriteCond %{HTTP_HOST} ^www\.example\.com [NC]
RewriteRule ^(.*)$ http://example.com/$1 [L,R=301]
NWak04030229
Thanks for that Ray. Where do I find this code to change it?
You create a file named .htaccess and place it in the root of your site.
NWak04030229
have tried this and now getting this page coming up when I try and purchase something (see attached)
Why is it going to localhost? are you testing it locally? I'll need more information to help you debug this. Can I get a URL and FTP access to a page where I can see the problem?
NWak04030229
see private message
On your confirm.php page lines 89-93 you have:
$WA_PP_ECO_Set_params[0][$nextIndex] = "ReturnURL";
  $WA_PP_ECO_Set_params[1][$nextIndex] = "http://localhost/pp_confirm.php";
  $nextIndex = count($WA_PP_ECO_Set_params[0]);
  $WA_PP_ECO_Set_params[0][$nextIndex] = "CancelURL";
  $WA_PP_ECO_Set_params[1][$nextIndex] = "http://localhost/cart.php?ppcancel=1";
It looks like you have it set up to use your localhost. That has to be updated to use your live site like:
  $WA_PP_ECO_Set_params[1][$nextIndex] = "http://www.usedmagic.co.uk/pp_confirm.php";
  $WA_PP_ECO_Set_params[1][$nextIndex] = "http://www.usedmagic.co.uk/cart.php?ppcancel=1";
NWak04030229
Thanks for that - have changed it and uploaded - will try out later. One last thing: When opening up the confirm.php page I get the attached message. Can you tell me what that is about?
I just updated eCart with a fix that should address this issue. Please reinstall the extension and you shouldn't get this error anymore.
