ECart Error message Connections[conn] has no properties.
Thread begun 12/05/2018 7:58 am by john70964 | Last modified 12/06/2018 8:42 am by Ray Borduin | 2672 views | 5 replies |
john70964
I am following the page http://www.webassist.com/tutorials/Integrating-Data-Bridge-and-eCart
I have come to the section Create your Orders pages
When I select Click WebAssist > Database > DataAssist Pages in the menu bar I get an error
Error inuilnitialize
I have closed and reopened DW but it made no difference
Any suggestions please?
Do you have any connections defined for your website? Can you go to the "Databases" tab and test your connection to see that it returns a list of tables?
john70964
Hello Ray
I decided to start again just in case I had made a mistake somewhere.
connections are OK
Under Database tables I have four tables showing theses were generated from the file ecommerce_Database.sql
orderdetails orders products and users
I did not get very far this time I opened Webassist>database>data assist pages and after about 30 seconds the same error appears
On the last occasion when I generated some pages I noticed Not Responding warnings but they disappeared and the page generated OK I also noticed the X for closing a file was appearing in red.
Regards
John
PS this came in the DataAssist Search wizard
This might just be that you had a connection that was deleted and it is trying to recover your settings. If you ignore the error are you able to continue with the wizard.
The "0" alert in Database Search was leftover from me debugging an issue. I've removed it and uploaded a new build, but it can be ignored until you do a reinstall of the extension.
If you send me a US phone number or Skpe contact information I can give you a call and do screen sharing to make sure you are able to get through the database pages wizard.
john70964
Hi Ray
I am following the tutorial at http://www.webassist.com/tutorials/Integrating-Data-Bridge-and-eCart
Some of the instructions may be out of date?
Is this the correct tutorial for now?
That tutorial should still be valid. If you post a US phone number or Skype contact information then I'll do screen sharing and debug this with you.
