img src displaying
Thread begun 12/05/2018 6:42 am by birdscreen398247 | Last modified 12/05/2018 1:00 pm by Ray Borduin | 1774 views | 3 replies |
birdscreen398247
img src displaying
I am trying to display an image in a table. The name of the image is stored in a table. I used MySQLIRecordset to create the recordset and a Mysqli connection.
I have the following code:
<?php require_once('../connections/siteguide2018.php'); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
$rsCountyMap = new WA_MySQLi_RS("rsCountyMap",$siteguide2018,1);
$rsCountyMap->setQuery("SELECT * FROM counties WHERE CountyID = ?");
$rsCountyMap->bindParam("i", "".(isset($_GET['CountyID'])?$_GET['CountyID']:"") ."", "-1"); //colname
$rsCountyMap->execute();
<!doctype html>
<html>
<head>
<meta charset="utf-8">
</head>
<body>
<table width="800" border="1" cellspacing="4" cellpadding="4">
<tr>
<td><img src="https://pabirds.org/siteguide/maps/county/<?php echo($rsCountyMap->getColumnVal('MapFileName')); ?>" alt="" name="CountyMap" width="400" id="CountyMap" /></td>
<td>&nbsp;</td>
</tr>
<tr>
<td><?php echo($rsCountyMap->getColumnVal("MapFileName")); ?></td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
</body>
</html>
The MapFileName name displays correctly in the second row of the table, so I know the table data is being correctly retrieved, but the related image does not display in the first row.
I tried changing the path to the image (../maps/county/ and /maps/county/). The full https: path works on other (older pages) on my site.
What am I missing?
You may have to use:
<?php echo($rsCountyMap->getColumnVal('MapFileName',false)); ?> in the image src.
If you give me a url where I can see the problem I could be more confident in my answer.
birdscreen398247
That didn't work.
If you go to: https://pabirds.org/siteguide/PAStatePage.php
Click on Adams (the first county on the list) and it will pass the variable to the page in question. Note that this is a preliminary page, just working out the procedures before finalizing the look and feel. There are other items on the page that I have not yet worked on, so ignore those error messages.
As you can see, the Site List in the upper right is a repeat region that is working fine (in response to my other post - thanks) and other pieces of information from tables are displayed. Just the img doesn't.
Frank
The path to the image it is adding to the page is:
https://pabirds.org/siteguide/maps/county/Adams.gif
which isn't correct (you can see by pasting it into your browser).... what is the correct full path to the image?
