Displaying validated entries and/or recordset values BUT in a dynamic drop-down menu?
Thread begun 12/04/2018 12:04 pm by Nathon Jones Web Design | Last modified 12/05/2018 1:29 pm by Ray Borduin | 1746 views | 3 replies |
When adding the WA Server Validations to any form, it quickly becomes apparent that when you submit the form, and validation fails, all of your form values are wiped and the user has to start the entire form again. I'm not sure why that is, but it's the current state of play.
So, you have to manually add the ValidatedField data as the default value for every field in your form, like so:
<input type="text" class="form-control" name="FirstName" id="FirstName" placeholder="First name" maxlength="30" value="<?php echo(ValidatedField("healthscreeningform_984","FirstName")) ?>" required>
But what if your form is populated by data from a recordset? Well, you have to double up the default value to include the ValidatedField data AND the Recordset data, like so:
<input type="text" class="form-control" name="FirstName" id="FirstName" placeholder="First name" maxlength="30" value="<?php echo(isset($_GET['v'])?ValidatedField("healthscreeningform_984","FirstName"):$rsEDITFORM->getColumnVal("SMCformFIRST")) ?>" required>
This is incredbily time consuming to configure, but it's working.
My problem is how to handle dynamic drop-down menus? At the moment I have the option values within a repeat region, like so...
while(!$rsCOUNTRIES->atEnd()) { //dyn select
<option value="<?php echo($rsCOUNTRIES->getColumnVal("SMCcountryID")); ?>"<?php if (!(strcmp($rsCOUNTRIES->getColumnVal("SMCcountryID"), (ValidatedField("healthscreeningform_984","Country"))))) {echo "selected=\"selected\"";} ?>><?php echo($rsCOUNTRIES->getColumnVal("SMCcountryNAME")); ?></option>
$rsCOUNTRIES->moveNext();
} //dyn select
$rsCOUNTRIES->moveFirst();
Two things this isn't doing. It's not displaying the Country from the Recordset ($rsEDITFORM), and it's also not remembering the ValidatedField data so the Country menu is wiped blank every time validation fails.
One thing that might be complicating this is that I have a sub-dependent State field which changes depending on what the user selects from the Country drop-down.
What is wrong with my code that it's not remembering the Country selection by the user, and how do I, like my other fields, also incorporate the Recordset country and region data?
This can be viewed at:
www.sportsmedicalcertificates.com/health-screening-form.php?tab1=1
Thank you
NJ
It looks like it would work to select the country after failed validation. I'd need FTP access to debug why it isn't.
If you set the default selection in your dynamic select Server Behavior to:
<?php echo(isset($_GET['v'])?ValidatedField("healthscreeningform_984","Country"):$rsEDITFORM->getColumnVal("SMCformCOUNTRY")) ?>
Just like you do in the input elements, then it should work the same way.
I'd also strongly suggest using webassist jquery client form validation. That catches most errors before the form submits and bypasses some of the complexities involved with server validation. Server Validation is a stronger validation and good for backup.
Thank you Ray.
Adding that to the dynamic select Server Behaviour, for the country field, seems to have done the trick and I've added it for the various region field options too but, because when the validation fails the page effectively reloads, it's not recalling the onChange behaviour that would have been initiated on the first submission of the form by the user selecting either the US or UK - both of which call dynamic sub-dependent drop-down menus.
Thankfully it does recall the State name and displays it, when validation fails, but if you'd selected, for example, the US you would usually be shown a drop down menu of states. When validation fails, you are just shown a standard input field. It's not ideal but to change it I'd need to look at the whole onChange behaviour which is currently this:
<script>
$("#Country").change(function() {
if ( $(this).val() == 425) {
$("#RegionsUS").hide();
document.getElementById('RegionsUS').disabled = true;
$("#RegionsOTHER").hide();
document.getElementById('RegionsOTHER').disabled = true;
$("#RegionsUK").show();
document.getElementById('RegionsUK').disabled = false;
else if ( $(this).val() == 426) {
$("#RegionsUS").show();
document.getElementById('RegionsUS').disabled = false;
$("#RegionsUK").hide();
document.getElementById('RegionsUK').disabled = true;
else {
$("#RegionsOTHER").show();
document.getElementById('RegionsOTHER').disabled = false;
</script>
Is there any way of simplifying the WA jQuery Client Form Validation? The speech bubbles aren't mobile compatible and there are simpler ways of displaying the error, for example highlighting the input field in red with a small text message below it.
Thank you.
NJ
The bubbles should be mobile compatible. What is the issue with mobile?
You could probably just add this to the bottom of the page right before the </body> tag:
<script>
$("#Country").change();
</script>
That should call the onchange code when the page loads so the appropriate form element would show.
