Dynamic Plug-in not working after upgrade
Thread began 12/01/2018 1:55 pm by Mohammed Aji Wajiro | Last modified 12/02/2018 7:54 pm by Ray Borduin | 94 views | 0 replies |
Mohammed Aji Wajiro
After upgrading to the new MySQLi version of databridge, the dynamic plug-in does not work and displays the following fatal error 'Cannot use isset() on the result of an expression (you can use "null !== expression" instead)'. The part of the code generated by the plugin that the error refers to is as follows: switch(isset(($rsCheck->getColumnVal("count(id_std)")))?($rsCheck->getColumnVal("count(id_std)")):""){
