Paging Issue
Thread begun 11/22/2018 10:42 am by Nigel | Last modified 12/05/2018 9:08 am by Ray Borduin | 4803 views | 15 replies |
Nigel
Paging Issue
Trying to set up paging for the admin section of a site with thousands of records.
Have applied recordset and repeat region (limiting results to 10) and navigation links for First, Last, Previous and Next.
The first time I click Next Page records 11-21 appear, as expected. Click Next Page again and the list grows, starting at record 11 but adding 10 each time.
Clicking Last Page produces a list of every record, starting at record 11.
I was hoping to get 10 records at a time displayed so the client could use update Multiple records on just the found set.
What am I doing wrong?
You probably aren't doing anything wrong. I think this may be a bug in the rsobj.php file that was introduced with a recent feature. Can I get FTP access and a URL to reproduce? I'll get it fixed right away and put out a new build.
Nigel
I'm running locally under MAMP (I wouldn't dare touch the live site until this is tested), so I can't give you FTP access or URL. Is there anything else I can send you to work with? Other files or a DB dump of the records?
Try updating the attached rsobj.php
I may have already corrected the issue. If that doesn't work I can do screen sharing with you to debug it on your localhost.
Nigel
No joy. How do we screen share?
Send me your Skype username and I'll text you that way to set up a time and we can do screen share.
Nigel
Don't currently have Skype and I need to leave very soon. I'll get it set up and get back to you tomorrow if that's OK?
Nigel
Just installed Skype.
I was able to reproduce the issue and get it fixed. Here is the updated rsobj.php (attached)
Nigel
Works great. Thanks Ray.
