create email
Thread begun 11/19/2018 10:00 am by esavvy349871 | Last modified 11/30/2018 11:22 pm by Ray Borduin | 3625 views | 8 replies |
esavvy349871
create email
I'm trying to use the webassist "send email" feature in the new MySQLi upgrade. This is for a recent site that I built in php 7.0. However, hosting service recently upgraded server and the "forgotten email retrieval" is the only thing that broke. I'm trying to rebuild the page and can't get the Send Email wizard to find the recordset to send the email to. I've attached the error message from the wizard and the error messages on the broken page prior to deleting and re-inserting the send email.
The send mail upgrade is only available as part of Data Bridge. It doesn't use either of the files referenced in the errors.
Those are just deprecated messages. You can turn them off in your php.ini file and ignore them and they won't effect the overall functionality of the page. If you have the latest version of databridge you can delete the references to the two files listed in the error messages since they are no longer in use.
esavvy349871
create email
I do have the Data Bridge upgrade - purchased 11/5. I can't connect to the recordset using the "send email" feature in the upgrade. Removing the to unnecessary file references just caused additional errors. I'd like to rebuild the page using the upgraded Data Bridge send email wizard. See the second attachment for erroe.
That is an issue with your database connection. Usually it is a problem with the testing server specified or the server url set in the testing server in your dreamweaver site settings. Make sure you can test your database connection from the connections window before trying to add the email contact form.
esavvy349871
create email
I'm getting closer. I'm able to connect to the database now and use the Send Email wizard. Now, I'm getting a new error:
1) Warning: Cannot modify header information - headers already sent by (output started at /home1/moahqorg/public_html/sent.php:4) in /home1/moahqorg/public_html/webassist/email/WA_Email.php on line 360
You probably have a blank line of code on sent.php on line 4... Blank lines and spaces can prevent redirects in php.
esavvy349871
Addition Email Problem
This post has been deleted.
esavvy349871
Send Email Form being blocked
