Adding attachments from recordset - need to specify folder
Thread begun 11/15/2018 2:42 am by georgina_barrett_187762 | Last modified 8/11/2021 7:21 pm by Ray Borduin | 4452 views | 23 replies |
Using the new MySQLi Send Email. I have successfully added 2 attachments from the entered value section. The problem I have is that I also need to select multiple values from a recordset. I have done this (see code below) however as with the other attachments I need to specify the folder that they are stored in (../clientconf/). I can add it with the entered value attachments but not with the recordset loop
$Email->addAttachment("../clientconf/".($Payments->getColumnVal("ATOLCert")) ."");
$Email->addAttachment("../clientconf/".($Service1->getColumnVal("UploadConf")) ."");
$Email->addAttachmentFromRS("service","UploadConf");
You would probably have to either manually add a loop for the recordset and use addAttachment(), or you could append the folder name to the column in the Recordset SQL statement like:
SELECT *, CONCAT('../clientconf/',UploadConf) AS Attachment FROM table
Oh thank you - I will use the CONCAT method
I have set everything up ok (or so i thought) and the email is sending however there are no attachments. Neither the entered value attachment or the repeat region attachments are sending. I have echoed the values to the page so i know there are values in there. I have tried putting absolute and relative urls.
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) { //WA Universal Email
$Email = new WA_Email("waue_email_conf_2");
$Email->Redirect = "request_Detail.php?ID=".((isset($_POST["RequestID"]))?$_POST["RequestID"]:"") ."";
$Email->From = "info@website.co.uk";
$Email->BurstSize = "200";
$Email->BurstTime = "1";
$Email->WaitTime = "1";
$Email->addTo("".((isset($_POST["Email"]))?$_POST["Email"]:"") ."");
$Email->addCC("".((isset($_POST["Email2"]))?$_POST["Email2"]:"") ."");
$Email->addAttachment("https://www.website.co.uk/clientconf/".($Payments->getColumnVal("ATOLCert")) ."");
$Email->addAttachmentFromRS("service","Attachment");
$Email->BodyFile = "../webassist/email/waue_email_conf_2_body.php";
if (function_exists("rel2abs") && $Email->Redirect) $Email->Redirect = $Email->Redirect?rel2abs($Email->Redirect,dirname(__FILE__)):"";
for ($emailGroup=0; $emailGroup<sizeof($Email->To); $emailGroup++) {
$Email->Subject = "".($request->getColumnVal("Title")) ." ".($request->getColumnVal("Surname")) .", ".($request->getColumnVal("Product")) ." ".($request->getColumnVal("ClientID")) ."";
$Email->send($emailGroup);
$Email->close();
The paths should be relative. http:// paths won't work for adding attachments.
If you can give me FTP access and a URL to reproduce the problem I can debug it and figure out why the attachments aren't sending.
Thank you, I have made the paths relative and managed to send an attachment by removing the recordset attachment. I think the problem I was having before was if the recordset is empty (or if there is a value in the recordset but there isn't an attachment on the entered value.)
Is there a way to say send attachment only if there is an attachment? I would need this on both the entered value attachments and the recordset value attachments.
You want to not send the email if there are no attachments?
That would probably require some hand coding. If you attach a copy of your page I can try adding it for you and send it back.
Thank you, no I still want to send the email even if there isn't an attachment. There are 2 types of attachments that get sent with the email. One that is populated from an entered value and the other(s) that come from a recordset. When I tested it before, if there isn't a value for both of these the other attachment doesn't send.
It should detect when the attachment doesn't exist. I've made a small tweak to the WA_Email.php file.... upload the one I have attached and see if that helps.
That works - thanks
