I need php mysql help
Thread begun 11/14/2018 8:15 am by lr_leal239405 | Last modified 11/26/2018 10:15 am by Ray Borduin | 6108 views | 19 replies |
lr_leal239405
Used the repeating table insert function - can't figure out first row display different
I'm not sure why table displays first row different. I used the repeating table and inserted my code in the commented out field. The link is on private msg. Only the first two work on link to see what i'm talking about. Anti Wrinkle Devices and Core Support Systems.
That page appears to be correct. I think the issue is on the page: inside_specs.php
I'd need FTP access to tell for sure.
lr_leal239405
it would be night tmrw then. Can't do the ftp access for now because it's employer's site. But I attached code snippet.
It looks like you didn't attach the page you just copied and pasted part of it, and I'd have to open it up in Dreamweaver and see the whole page to get anywhere. We can look at this in a premier ticket if you can't give me FTP access.
lr_leal239405
After 6 EST is ok with me. This is not the only thing. I have to show you my screen but can't do the ftp because it's my employer data. The other is a mysql selecting from three tables and iterating the title then each header when there is one.
What number should I reach you at?
lr_leal239405
see private
I'll call you direct after 6pm EST tomorrow. I'll walk you through setting up screen sharing when I call.
lr_leal239405
Here's the full spec sheet php file:
lr_leal239405
Did you try calling me?
