Dynamic Plugins
Thread begun 11/13/2018 11:44 am by vernon webb | Last modified 11/19/2018 10:14 am by Ray Borduin | 4343 views | 10 replies |
vernon webb
Dynamic Plugins
We worked on these before and I'll be damned if I remember how to do them. Would you mind doing one for me?
It looks like you somehow deleted two recordsets that were used for this:
$rsCOMPANY_ACTIVE
and
$rsCOMPANY_INACTIVE
I was able to add them back to the page and it seems to be working now.
vernon webb
This post has been deleted.
vernon webb
Not sure I want to mess with this as I apparent keep messing it up. When the page loads it loads all the Active clients, when we make a change it on the Client Status to Inactive then it changes to that. I need an All option. I think there is some stuff in the redeye file... again I don't want to break it...
If you don't select any from the list, then all would be returned by default. You could just change the text from "Please Select One" to "Show All" in the redeye.js file.
vernon webb
They want the ability to be able to select certain items from both Active and Inactive at the same time, but only when they chose to. Right now when the page loads it loads with Active selected, which populates with only Active and when Inactive it only selects those, they want it to be All automatically on page load and then if they select Active/Inactive it populates accordingly, make sense?
I added that. I had to add a new array to the search php page and sort it and I had to update the redeye.js file to account for it. Please download those two files to make sure you don't accidentally overwrite them in the future.
vernon webb
A little problem with this...
Try refreshing your cache.... they are listed for me when I try to reproduce the problem you describe.
vernon webb
The odd thing is somethings that are active and somethings that are inactive show but not all things. For instances, none of the Allstate clients show...
