Truncated incorrect DOUBLE value
Thread begun 11/13/2018 6:48 am by vernon webb | Last modified 11/14/2018 10:23 am by Ray Borduin | 3996 views | 8 replies |
vernon webb
When select multiple records to search I get the error message:
Truncated incorrect DOUBLE value:
I'm on vacation and I don't have access to your FTP information or the login for your site. Please reply with that information in the private area and I'll take a look.
This error means that you have the data type set for a recordset set to an integer or number value and you are passing in text. If you attached a copy of the page that shows the error I could probably tell from that as well.
vernon webb
I have a few things to work on today so am hoping I don't need a lot of help. However the FTP is as follows:
Please send the login information for the site itself. Also attach the results page, I think that is the one showing the error.
vernon webb
here you go
In your file: admin/plugins/clientcompany_clientname.php you have:
<option value=" ">Please select one..</option>
It expects a number to be passed in for the contact to be a number and you are passing a space. You just have to update it to:
<option value="">Please select one..</option>
since blank values are ignored. I've updated it for you.
vernon webb
Disregard my last message here, I fixed this
vernon webb
Ok so I made a change here because it wasn't working at all and now it's broke what you did.
I added an All option on line 290:
<option value="" selected="selected">All..</option>
The reason I've added it is if nothing is selected it was returning no results on the results page. But now that I added that, selecting Active or Inactive in the Client Status no longer works.
It looks like you made an update to the page without downloading the page that I fixed first and undid my changes. I have fixed it again now. Please make sure to download the page before making any changes so that this doesn't happen again.
