Field 'FieldName' doesn't default value
Thread began 11/12/2018 9:15 am by Jose | Last modified 11/13/2018 6:25 am by Ray Borduin | 484 views | 2 replies |
Jose
Hi there, from few time ago I have noted this issue witch is that is required null in order to submit a form in updating or inserting. before I use none, null, or whatever I wanted but now it's required to set a value which it's forcing to update all my database fields. So I think that is tedious for me. I'm using queryobj.php 2.16 if you have solved this already. I read about it but I couldn't solve it my self.
You can set the default value to use for any field in the update server behavior bindings. The default might be "blank" but you can also set it to "null" or "default" or "ignore". If you attach a copy of the page I could show you where in the code that is set, but it can also be set in the server behavior user interface when the field values are specified.
Jose
Okay, thank you Ray.
