I need to create a shopping cart sort of thing
Thread begun 11/11/2018 3:23 pm by mrs | Last modified 11/12/2018 3:29 pm by Ray Borduin | 826 views | 1 replies |
mrs
There's a number of questions in this one, so bear with me...
I need to allow users to add products to a cart, but the cart doesn't take payment. It just submits content for a quote. I was thinking of doing it something like this:
- The user visits the site
- I create a session that has a random generated number. Something like: if session isn't set, then generate a random number.
- When the user adds the product to the cart, the product ID and the random number get stored together in a database table via an insert.
- If the user wants to save the cart contents and return at a later date on a different device, then they to save their email address to a different database table. At the same time as entering the email address, the site inserts the random number into the same record.
- When the user returns, the session will create a new random number because the user hasn't identified themselves yet. When the user signs in using their email address the original stored random number overwrites and repopulates the session ID in order to retrieve cart contents. This allows the user to continue shopping or submit the cart for a quote.
Is this feasible?
Is this a lot of work that could be achieved in a simpler way? Are there any issues that you can foresee that I can't?
Would you store as a DB record or rather use something like a cookie? (I'm not quite sure how to work with cookies and how I might retain more than one product... there be dragons!).
The only problem I can see with the above is if the user is returning and they've added more products to the cart before signing in to retrieve previous cart contents, then any new products added to the cart after logging in might be lost or overwritten, which doesn't make for a very good UX! So (final question), how might I combine the newly added products to those already saved without losing either?
Thanks.
session_id() is a random number that is always unique, so you wouldn't have to generate one.
A cookie wouldn't work for your use case since it wouldn't be available from another device, it would just persist on the original device.
I wouldn't bother saving the cart contents with a session_id() since they wouldn't be able to retrieve the cart unless they log in anyway. Just tell them to log in to save their cart contents, and save it based on their userid in the database only when they are logged in. You don't need the random id... it doesn't really give you anything.
Then when someone logs in you can automatically retrieve the cart from the database into a recordset and use "Get Cart Contents from Recordset" to populate the cart. It won't remove the existing items from the cart, you would have to add the Clear Cart server behavior manually if you wanted to do that.
