Testing connection
Thread begun 11/11/2018 1:08 am by neo314 | Last modified 11/12/2018 3:08 pm by Ray Borduin | 1252 views | 2 replies |
neo314
Testing connection
I am looking to update a hand written object using Webassist MySQLi.
In the object, one of the first things I do is test my connection.
// Make sure we can select the database
mysql_select_db($this->db, $this->conn) or die(mysql_error()."<br>UNABLE TO SELECT DATABASE myClass Error");
How can I replicate that using WA_MySQLi_Query or similar object?
Use the connection dialog to add a connection. That code is automatically included and you can view it in the newly created connection file.
neo314
Thanks, but this is a dynamic check when the class is called to ensure the connection passed to it is valid. I ended up writing the whole revision using mySQLi natively. It was easier than expected. I thought I had a great deal more rewrite to do.
if($this->conn->connect_errno > 0){
die('UNABLE TO SELECT DATABASE myClass Error<br />[' . $this->conn->connect_error . ']');
