Admin 'update' page URL parameter doesn't show; mysql syntax error
Thread begun 11/08/2018 1:11 pm by tmcbinc99963 | Last modified 6/12/2019 1:47 pm by Ray Borduin | 5894 views | 10 replies |
tmcbinc99963
Admin 'update' page displays differently when accessed from 'search results > update' and 'search results > detail > update'.
When accessed from 'search results > update', the data displays as it should, with correct URL parameter.
When accessed from 'search results > detail > update', there is no URL parameter and the following error message displays:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'LIMIT 0, 10' at line 1
Haven't been able to find any syntax errors, and various 'get' and 'post' iterations never display the URL parameter.
Looks to me like the error should be in the detail page form, since the update page displays incorrectly only when accessed from that page. However, adjustments to the form method and/or 'update' button return the same errors.
Do both of these issues result from the same problem, or are there multiple problems here?
UPDATE: Changing the $_GET in the mysql query code at top of 'update' page eliminated the syntax error, but of course none of the data displays when the 'update' page is accessed from either the 'results' page or the 'detail' page.
Files attached. Live view details in private message.
It looks like you may have sent me the wrong versions of these pages. These are MySQL version and I think your current site is updated to MySQLi. If you send me the correct pages then I can see what might need to be updated.
tmcbinc99963
The site is still MySQL; hasn't been upgraded.
You could try updating the details page <td> where the update button appears to:
<td><input type="button" value="Update" class="formButton Sharp" id="Update" name="Update" onclick="document.location.href='prod_update.php?ID=<?php echo($row_WADAprod['ID']); ?>';" /></td>
That might solve the issue.... if not, just send me ftp access and a url to reproduce and I can fully debug and figure out what is going wrong.
tmcbinc99963
See private message for access.
I got the update page working. There were several issues including using a form GET instead of POST, mismatched form element names, fields bound to recordsets when they should be set to form values, and others.
tmcbinc99963
The Update page still has no data when accessed from the Detail page (with no URL).
Please post steps to reproduce the issue and I'll debug it. What page should I go to, what should I click, etc...
tmcbinc99963
See private message
You had a repeat region in the middle of the prod_detail.php page on the WADAprod recordset that was looping and didn't have any content by the time it got to the bottom of the page. I removed the loop and it appears to work properly now.
