DataAssist Pages wizard does not write the correct query code, "ambiguous error".
Thread begun 11/07/2018 3:57 pm by Jonas | Last modified 4/16/2019 8:55 am by Ray Borduin | 4757 views | 22 replies |
Jonas
It appears that the DataAssist Pages wizard does not write the correct query code. Firstly, it is not written consistently. Sometimes with `` sometimes without. Secondly, it sometimes misses the table name before the column name, which becomes an "amigous" error message.
When I let Querybuilder fix the problem, orders will not be the way I want it. It appears that query builder is based on the order in the database itself. But I have changed this in the DA Pages wizard.
So I have to correct the code, which is a little frustrating to do every time I create new CRUD files using DA.
Below is the code from both Detail page and Results page. Both the wrong code that DA creates and the code that I corrected.
I hope you can add this to your "to-do list" to the next update.
Detail page, DA code with error from browser:
"SELECT id, `llSubject`.`menu_name` AS llSubject_menu_name, llCountry.country AS llCountry_country, `llCategory`.`content` AS llCategory_content, content, landmarkFeature, link1, link2, date, date_update, user_id FROM llPage LEFT JOIN llSubject ON llSubject.id = llPage.subject_id LEFT JOIN llCountry ON llCountry.code = llPage.countryCode LEFT JOIN llCategory ON llCategory.id = llPage.category_id WHERE id = ?
Column 'id' in field list is ambiguous"
Detail page, my correct code:
"SELECT `llPage`.`id`, `llSubject`.`menu_name` AS llSubject_menu_name, `llCountry`.`country` AS llCountry_country, `llCategory`.`content` AS llCategory_content, `llPage`.`content`, `llPage`.`landmarkFeature`, `llPage`.`link1`, `llPage`.`link2`, `llPage`.`date`, `llPage`.`date_update`, `llPage`.`user_id` FROM llPage LEFT JOIN llSubject ON llSubject.id = llPage.subject_id LEFT JOIN llCountry ON llCountry.code = llPage.countryCode LEFT JOIN llCategory ON llCategory.id = llPage.category_id WHERE `llPage`.`id` = ?"
Results page, DA code with error from browser:
SELECT id, link2, `llSubject`.`menu_name` AS llSubject_menu_name, llCountry.country AS llCountry_country, `llCategory`.`content` AS llCategory_content, content, date_update FROM llPage LEFT JOIN llSubject ON llSubject.id = llPage.subject_id LEFT JOIN llCountry ON llCountry.code = llPage.countryCode LEFT JOIN llCategory ON llCategory.id = llPage.category_id
Results page, my correct code:
SELECT `llPage`.`id`, `llPage`.`link2`, `llSubject`.`menu_name` AS llSubject_menu_name, `llCountry`.`country` AS llCountry_country, `llCategory`.`content` AS llCategory_content, `llPage`.`content`, `llPage`.`date_update` FROM llPage LEFT JOIN llSubject ON llSubject.id = llPage.subject_id LEFT JOIN llCountry ON llCountry.code = llPage.countryCode LEFT JOIN llCategory ON llCategory.id = llPage.category_id
Yes. It is probably not detecting if the same column name exists in both tables. I will update it to always use the table name so that the issue won't occur... Thank you for reporting this issue and solution. I'll add it to my to do list.
Justin@AdventDesign
Has this been updated? I'm having the same problem.
I think this should be fixed. Have you reinstalled recently?
Justin@AdventDesign
Less than 2 weeks ago
Please attach a copy of the page with the issue. I'll take a look. What is the full error you get?
Justin@AdventDesign
This is the current error:
SELECT SQL_CALC_FOUND_ROWS tbl_homes.id AS id, tbl_homes.title AS title, `sl_types`.`title` AS sl_types_title, `sl_categories`.`title` AS sl_categories_title, tbl_homes.sqft AS sqft, tbl_homes.beds AS beds, tbl_homes.baths AS baths, tbl_homes.featured AS featured, tbl_homes.dateupdate AS dateupdate, `sl_publish`.`title` AS sl_publish_title FROM tbl_homes LEFT JOIN sl_types ON sl_types.id = tbl_homes.type LEFT JOIN sl_categories ON sl_categories.id = tbl_homes.category LEFT JOIN sl_publish ON sl_publish.id = tbl_homes.publish WHERE ((`id` = 1) and (`type` = 4) and (`category` = 7) and (`subcategory` = 1) and (`community` = 1) and (`beds` = 1) and (`baths` = 1) and (`garagemin` = 0) and (`garagemax` = 0) and (`publish` = 1)) LIMIT 1000
Column 'id' in where clause is ambiguous
I should note, I've already modified the following query trying to fix the original error, which was a similar ambiguous error. I got the the point where the error is in the 'where' clause, and I don't quite understand how the search query builds that portion. The original before my changes is attached with the "_original" at the end of the name.
I think you should just manually update:
(`id` = 1)
(tbl_homes.`id` = 1)
I don't think the wizard actually does this WHERE clause for you... you may have added it manually? I'll look into it though. Thanks for the information.
There is a preference in WebAssist->Preferences where you can increase the delay while running the wizard. Look in the "Wizard Settings" section.
Justin@AdventDesign
See PM
Justin@AdventDesign
Where do I find those settings?
Never mind... Just found the "Preferences" under "WebAssist" menu...
