PHP Version 7+ with eCart
Thread begun 11/07/2018 9:44 am by Me | Last modified 11/20/2018 1:25 pm by Ray Borduin | 5524 views | 3 replies |
Me
I am getting the following errors with ecart using PHP 7 or greater
[07-Nov-2018 17:42:39 Europe/London] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCart_Rule has a deprecated constructor in /home/hairheav/public_html/new/WA_eCart/WA_eCart_Definition_PHP.php on line 4
[07-Nov-2018 17:42:39 Europe/London] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCartDefinition has a deprecated constructor in /home/hairheav/public_html/new/WA_eCart/WA_eCart_Definition_PHP.php on line 19
[07-Nov-2018 17:42:39 Europe/London] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCartDisplayCSSLooper has a deprecated constructor in /home/hairheav/public_html/new/WA_eCart/WA_eCart_Definition_PHP.php on line 1000
Is there a resolve for this? I am using eCart 6.1.2
UPDATE: May I also ask. Is the latest mysqli version compatible with PHP7+. I ask because, it has come to light that there are memory errors - Out of Memory - when using the code on a server using PHP7+ BUT, if we roll the server back to PHP5.6 all works as expected.
Please advise.
If you edit your eCart object and click "ok" it should update it to the latest version and fix the warnings as long as you have the latest version installed. (make sure to upload the entire WA_eCart folder when you are done).
You probably have different settings in your php7 .htaccess file with a lower memory_limit. If you update it to increase the memory and match your 5.6 version then the error should go away. It is fully compatible with php7.
Me
Seems I still have this problem when running php 7 +
[20-Nov-2018 17:56:19 Europe/London] PHP Fatal error: Out of memory (allocated 2097152) (tried to allocate 1919906960 bytes) in /home/hairheaven/public_html/webassist/mysqli/rsobj.php on line 537
Interestingly, when running PHP5.6 (it works fine) memory limit is only set to 32m when we swtich to PHP 7 + we ramp the memory all the way to 2048 and still get this issue...which cause the site to break and not load properly OR load differently each time we hit the browser refresh...as in sometimes some parts will show and other will not,
Any ideas would be gratefully received...we really want to run in 7 not PHP5.6
regards
Andrew
If you send me ftp access and a url with steps to reproduce the error then I can debug it and try to find a solution.
