'Type: text' for recordset variable not working
Thread begun 11/01/2018 9:19 am by s.joiner74419001 | Last modified 11/01/2018 6:41 pm by Ray Borduin | 439 views | 1 replies |
s.joiner74419001
I am wanting to add a second variable to a recordset that will have its value determined by a URL parameter. the parameter will be "?status=Unpaid" so I need the variable to be a 'Text' type. but I get an error message ( Missing type for variable:status - Missing Run-Time Value for variable"status ) when trying to OK the recordset update. ( see screen shots in attachments )
How do use a variable here that has a text value?
Thanks in advance
You can't name the parameter the same name as a column that is in your SQL statement.
Try renaming your parameter to StatParam instead of just Status and this should work.
