Universal Email
I upgrade my Data Bridge and can't find edit button for mail body?
Img 1 old Data Bridge
Img 2 new Data Bridge
I am using dw cs6
Can you please help me?
I am using dw cs6
The email body is now managed through a separate php page automatically. After application the body file will be opened automatically on first apply, or listed in the server behaviors panel to open and edit manually after.
Thank you for reply Ray
How can i add form elements content (text area, text field...) in mail body?
Just open the body field with dreamweaver and customize it however you please.
Dear Ray,
I made a simple email form but I am not getting any attachments?
See PM for FTP login.
Files are in attachment.
Thank you!
I just found a solution, just addad enctype="multipart/form-data" in form.
Hi Ray,
I create simple email form and it works fine on my testing server.
But on client server i am getting this error:
Warning: escapeshellcmd() has been disabled for security reasons in ..../webassist/email/phpmailer/src/PHPMailer.php on line 1606
Warning: Cannot modify header information - headers already sent by (output started at .../public_html/ivannastovic.com/s.php:17) in .../webassist/email/WA_Email.php on line 405
The message is sent but instead opening thank you page i get blank page with this error.
When I set the mail method to smtp, I receive only this error and message is not sent:
Please advise.
Ivica
The solution for the first problem is to use SMTP, which won't require the escapeshellcmd() function call.
The error when you use that method is probably caused by blank space on the page. If you attach a copy of the s.php page I could look, but it appears it is an issue on line 17 of that file.
Dear Ray,
I am getting this error message in email: Deprecated: Function get_magic_quotes_gpc() is deprecated in .../WebAssist-Block/Block.php on line 47.
This is on server php 7.4
How can i fix it?
