Update Universal Email to Send Mail
Thread begun 11/01/2018 4:28 am by eric284736 | Last modified 11/13/2018 2:09 pm by Ray Borduin | 5265 views | 12 replies |
eric284736
Hi Ray,
I have an eCart 6 confirm page that I want to change over to use Send Mail.Do I need to update all of the server behaviors on this page? Do any of the includes go away?
thx
Eric
The MailFormatting.php include may need to be deleted manually, but everything else should be taken care of just by reapplying the server behavior.
Just open the email server behavior and click "ok" and it should update the code. The only thing you would have to do is delete the reference to the include file I mentioned above.
eric284736
Hi Ray,
I did the update but I am having issues with the email not being sent and it is not being logged into the database as a fail or success.
It seems the checkout success page does not load. It may be an issue with the email object on the waue_confirm_3.php page.
See the PM
Thanks,
Eric
Whenever you refer to a variable in the email body that is defined on the main page, you have to add a "global" declaration on the top of the email body page. In your case I think you just have to add:
global $loadTime, $eCart1;
That should allow you to reference them in the email body. It would make sense that the email would not send with that line missing.
eric284736
Thanks Ray!
On the waue... page where this is referenced:
//Global Variables
$WA_MailObject = WAUE_Definition("mailx2.newtekwebhosting.com","587","","","","");
if ($RecipientEmail) {
$WA_MailObject = WAUE_AddRecipient($WA_MailObject,$RecipientEmail);
else {
//To Entries
If I am using SMTP and I need to authenticate the email should this not be updated to include the email and password?
thx
Eric
That page isn't even used anymore with the latest version. All of the code is on the page itself and the body file.
eric284736
Thanks Ray. I will be testing shortly.
One other question since I have a few sites running eCart and the UE. WIll it be problematic to just update the UE behavior only and keep the old eCart 6 mysql behaviors in place? I will update everything in time but there seems to be more and more email failures using the old UE.
Thanks,
Eric
No that shouldn't be an issue. The code runs independently.
eric284736
Thanks Ray!
Ok I have tested the cart and send email but it is not working.
Once it goes to the checkout_success.php page the screen is blank. But it also fails to send the email and to log the failure in the email_log table.
Thanks,
Eric
eric284736
I am testing the send email setup on another server account and it does send the email correctly but it does not enter a log entry for the email. These are two separate issues so would you prefer a different thread for this issue?
thanks
Eric
