Send alert email when a user effect login
Thread begun 10/28/2018 6:16 am by Mike | Last modified 10/29/2018 3:21 pm by Ray Borduin | 3863 views | 5 replies |
Mike
Hello,
I need to create this behaviour with "Send Email" of DataBridge (installed 2.3.2 version):
1) login page;
2) send an email to the administrator when a user effect login (with the user's details in the email, included the IP address).
Now I've tried to create this "send email" (see the code below) in the login page but works only if the page not redirect (so the user after clicking "login in", remain in the same page... which also generates a wrong behaviour sending the email every time the user refresh the page).
Is possible to send an email when the user is redirect to the starting restricted page?
Also, how can I include the user's IP address in the email?
if (WA_Auth_RulePasses("Logged in to pcms2_users")) { //WA Universal Email
$Email = new WA_Email("login_2");
$Email->From = "test@test.com";
$Email->Method = "smtp";
$Email->Host = "mail.test.com";
$Email->Port = "587";
$Email->SMTPAuth = true;
$Email->SMTPSecure = "tls";
$Email->Username = "test@test.com";
$Email->Password = "password";
$Email->addTo("test@test.com");
$Email->BodyFile = "../../../webassist/email/templates/waue_login.php";
if (function_exists("rel2abs") && $Email->Redirect) $Email->Redirect = $Email->Redirect?rel2abs($Email->Redirect,dirname(__FILE__)):"";
for ($emailGroup=0; $emailGroup<sizeof($Email->To); $emailGroup++) {
$Email->Subject = "Subject email";
$Email->send($emailGroup);
$Email->close();
If you put the redirect in the send email server behavior instead of the login user behavior then it should work properly.
Mike
I've removed the url in the "Success Redirect" but if "Return to restricted page" in "MySQLi Log In User" is activated the "Go To Page" set in the "Send Email" not works... works good only if the user enter from the "login.php" page.
... but, anyway, it's not important I can use it without email alert (I think it's more important "Return to restricted page" option).
Thanks!
I've just made an update to the DataBridge v2 extension that will allow you to track the redirect without redirection. Then you can reference the redirect in the email after.
You would just update the authentication.php file to make sure you have v2.11 of that file (listed on the first line).
Then you can turn on the NoSuccessRedirect option (line 46).
After that your authentication server behavior will not redirect to the success page. You can then use the redirect in the email server behavior:
<?php echo($Authenticate->Redirect); ?>
Mike
Thanks, now it's perfect!
I had the wrong syntax in my post... should have been ->Redirect not ->Trigger.... I've updated it.
