Ray: DataBridge 2.3.2 / I am having trobule getting login.php to work. Login page won't resolve keep gettin a 404 error, Need assistance please. Thanks
Thread begun 10/26/2018 4:06 pm by jhaa32156951 | Last modified 12/02/2018 8:30 pm by Ray Borduin | 7874 views | 19 replies |
jhaa32156951
You need to check here is the ftp and url info.
FTP
ftp://0365f9c.netsolhost.com
ftp1898862
RavLunatic47#*
https://www.cnymusicians.org/local78mem/new_members/login.php
login for the page is MUSICIAN ID = 006
pass = violin4716
Is the code being generated wrong - i did not change anything.
another question - if the password db col. is encrypted MD5 how to i get forgotpassword.php to return the password unencrypted??
It looks like the form action is generated wrong on login.php.
<form class="Basic_Default" id="LogIn_Basic_Default" name="LogIn_Basic_Default" method="post" action="local78mem/new_members/login.php">
should probably just be:
<form class="Basic_Default" id="LogIn_Basic_Default" name="LogIn_Basic_Default" method="post" action="login.php">
If you didn't change anything, then the code must have been generated wrong somehow. I looked into the logic for that code and it appears correct, so I'm not sure what would have caused it.
MD5 is not un-encrypt-able. You have to give someone a reset password if you are using MD5 instead of sending it to them.
jhaa32156951
Did not change that block of code it was generated that way.
userupdate.php not working.
just remove this line from your page:
<?php require_once('@@ConnectionPath@@'); ?>
I'm not sure why, but some of the variable replacements aren't working for you. I'm going to run the wizard a few times on my side to see if I can reproduce and fix the problem. If not, I may need to do screen sharing with you to figure out why this happens for you.
Please post a US phone number or Skype contact information so that I can call you if necessary.
jhaa32156951
Ray I did try removing that line of code and got this error: SELECT SQL_CALC_FOUND_ROWS * FROM MUSICIANS WHERE MUSICIAN_ID = ? LIMIT 0,1
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '? LIMIT 0,1' at line 1
I just tried calling and got voicemail. Please call me using the number at the bottom of the webassist.com site when you are available.
jhaa32156951
Tired calling - no answer.
I was able to re-run the wizard and get this fixed in a screen sharing session. There is a bug in the recordset on the user update page that I'll address in a new build in the next day or two.
jhaa32156951
File upload
File upload uploads the file with out a name. Here is the code that is generated:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../../uploads/ensemble/",
'FileName' => "".((isset($_FILES["Last"]))?$_FILES["Last"][""]:"") ."",
'DefaultFileName' => "",
'ResizeType' => "4",
'ResizeWidth' => "640",
'ResizeHeight' => "480",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Submit"]) || isset($_POST["Submit_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "EnsemPicture", "0", "", "true", $WA_UploadResult1_Params);
Is it correct? Thanks again John
