DataBridge 2.3.2 not install on Dreamweaver
Thread begun 10/25/2018 10:59 pm by Mike | Last modified 10/29/2018 2:28 pm by Ray Borduin | 6105 views | 16 replies |
Mike
Hello,
this morning I've reinstalled DB extension on my DW 2019 (macOS 10.14) but the installer failed.
When I open a page on Dreamweaver I don't have the typical installer process and nothing happen (I see the WebAssist menu but if I click on the voices I receive nothing or js errors).
The version of DataBridge downloaded is 2.3.2 and I'm using DMXzone extension manager.
How can I fix it?
Is possibile to have the previous version 2.3.1?
Make sure to open a new page after installing. That should launch the secondary installer. Then restart dreamweaver before accessing the extension. I have confirmed there is nothing wrong with the installer in the latest version.
Mike
Maybe is a problem with DMXzone Extensions Manager... usually it sends me a prompt when I install something not from DMXzone but from yesterday no more messages... do you have some alternative to suggest me (in addition to PVII, that I don't find very stable on MacOS)?
Try force quit in the extension manager and then open it again. I've found sometimes it won't reinstall an extension you have uninstalled unless you force quit in between.
Mike
Nothing, it's impossible to install the latest 2.3.2 version on MacOS 10.14.
I've tried also with PVII's extension manager and the result is the same.
I've tried also to install on other DW versions (Dreamweaver 2015) and... nothing.
Instead with other extensions works good and DMXzone extension manager show me correctly the prompt in attachment.
Could you send me the old 2.3.1 version, I need urgently to finish a work.
Thanks.
Mike
... and obviously I've reset the Dreamweaver's preferences every time I reinstalled the extension.
Please post a US phone number or Skype contact information and I'll do screen sharing with you and debug this to get it working properly.
Mike
Don't worry Ray, I've restored the old 2.3.1 from a previous dw preferences backup.
I've lost all day to install the 2.3.2 but it's impossible.
I hope that 2.3.1 is stable enough to build a security area with "Secure pages" wizard.
It has only one or two files that were changed, so they are nearly identical. Mostly an update to fix multiple insert. If one doesn't work install then the other wouldn't either, but I'm glad you got it working.
Let me know when you are ready to upgrade and I'll help you figure out what is going wrong.
Mike
I've tried to install again the 2.3.2 this morning and now it works... maybe with the old dw preference restored from backup (with DB 2.3.1) fixed something in the installer, I don't know what exactly happened but now I've 2.3.2 installed.
A last question, where is possible to see the version number of DataBridge installed on Dreamweaver (on WebAssist "Preferences" or "Preset Manager" I don't see nothing)?
