Truncated inccorect INTEGER value
Thread begun 10/25/2018 10:05 am by vernon webb | Last modified 10/25/2018 12:04 pm by Ray Borduin | 1562 views | 3 replies |
vernon webb
Truncated incorrect INTEGER value
Trying to insert a record and getting an truncated incorrect INTEGER value on insert.
You have your parameter set to an integer, but you are passing an email address. You just have to update the data type in the recordset that matches the query listed in the error.
vernon webb
It's not set to integer, it's set to text for a vachar field. I also checked all the others so at a loss.
In the Recordset... the parameter is set to "integer". Open the recordset and edit the parameter.
