Another Error On Insert
Thread begun 10/23/2018 11:04 am by vernon webb | Last modified 10/23/2018 12:48 pm by Ray Borduin | 799 views | 1 replies |
vernon webb
I get another error on insert for the below page:
The error displays the SQL for the recordset and "Truncated incorrect INTEGER value: 42.33"
In your Update Record server behavior for the billing table you have the data type for : weekday_addon set to "integer" but you are trying to update the value to 42.33, which is not an integer. If you open the update server behavior and set the submit as value for that column to "double" then it will allow you to insert numbers with decimals.
