Use GET parameter as Insert Record trigger?
Thread begun 10/23/2018 6:42 am by Mags | Last modified 10/23/2018 12:40 pm by Ray Borduin | 807 views | 1 replies |
Mags
I'm converting all my old captcha widgets to use Google's reCaptcha instead. It works fine when using email behaviors, however I have a few registration forms which insert a record in the database and also send an email. I don't think I can apply WA server validation to the reCaptcha widget as it's just a div (i.e. <div class="g-recaptcha" data-sitekey="xxxxxxx"></div>, however this means that when the Submit button is pressed (the trigger for inserting the record and sending the email), the email won't send but the record is being written to the database as long as all the other validations are passed. I thought a way around this may be to use a GET parameter as the Insert Record trigger instead of the usual Submit button pressed option, i.e.:
// WA DataAssist Insert
if ((isset($_GET["sent"]) && $_GET["sent"] == "true")) // Trigger
It did write a record to the database but didn't post the info from the form! Am I missing something here, or is there another way I could add reCaptcha to the WA Server Validations?
You need to follow the recaptcha documentation on how to validate the entry with php.
