Activation key is not working
Thread begun 10/23/2018 6:18 am by BjB | Last modified 10/25/2018 10:47 am by Ray Borduin | 3729 views | 8 replies |
BjB
I've tried both activation keys and they are not working.
Try reinstalling the extension.... maybe you were using the BETA and those keys are no longer active.
BjB
Ray, I am on Data Bridge 1.2.4 using Dreamweaver CS6. I've been using this version since it was made available. Your site says that it is no longer supported in CS6. Is that correct? Do I need to upgrade to Data Bridge 2 for $199.99? I'm also using MySQLi version 1.0.5.
My Activation Keys are still not working after refreshing them, uninstalling Data Bridge and reinstalling it. I also restarted my system and still not working.
It looks like there is an issue with the activation screen in DataBridge v1 checking for the v2 serial. I'll get that fixed right away and upload a new DataBridge v1 build so you can install it again.
I was unable to find an issue to address in the extension. Please post a US phone number or Skype contact information and I can do screen sharing with you in order to determine the cause and fix for this problem.
BjB
I'm about to leave for the day. I'll be in tomorrow at 8 am Central Time. Can you call me at the number below between 8:30 and 11:30 am?
I just tried calling, but I'm a bit outside the window you suggested, so you may be at lunch. Please reply to this post and let me know what other times you might be available today.
BjB
Im back from lunch now.
I'm calling you now.
