Search multiple columns via one text box
Thread begun 10/22/2018 4:33 pm by mrs | Last modified 1/04/2019 11:33 am by Ray Borduin | 3508 views | 6 replies |
mrs
How can I get one text box to search multiple columns of a DB table?
I've got these four columns created by DA where I have had to create a text box for each:
$searchWADAtbl_product_WADbSearch1 = new WA_MySQLi_Search("WADAtbl_product","");
if (isset($_GET["Search"]) || isset($_GET["Search_x"])) {
$searchWADAtbl_product_WADbSearch1->clearSearch();
$searchWADAtbl_product_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"Includes", "join"=>"AND"), array("fld_p_name"), "s", "fld_p_name");
$searchWADAtbl_product_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"Includes", "join"=>"AND"), array("fld_p_descrption"), "s", "fld_p_descrption");
$searchWADAtbl_product_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"Includes", "join"=>"AND"), array("fld_p_collection"), "s", "fld_p_collection");
$searchWADAtbl_product_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"Includes", "join"=>"AND"), array("fld_p_manufacturer"), "s", "fld_p_manufacturer");
This is what I have tried, but, guess what... it didn't work =D
$searchWADAtbl_product_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"Includes", "join"=>"AND"), array("fld_p_name"), "s", "fld_p_name", "fld_p_descrption", "fld_p_collection", "fld_p_manufacturer");
I've done this before with the pre-MySQLi version of DA, but it's beaten me this time!
Also, do I need , "join"=>"AND" if I have only one search box?
Thanks.
If you use the "keyword" search type it will allow you to select multiple columns in the UI. The correct code would be something like:
$searchWADAtbl_product_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"Includes", "join"=>"AND"), array("fld_p_name", "fld_p_descrption", "fld_p_collection", "fld_p_manufacturer"), "s", "fld_p_name");
mrs
That worked. Thanks Ray.
The old method used to retain a session and utilise it to keep the search results returned until you killed the session off. Have you stopped that from happening by default with the new extension?
Is there a way to keep the session like the old way?
It should still maintain the search. If that isn't working, please send me a URL and FTP access and I can look into why.
mrs
Hi Ray, I thought I had this working... I'm sure it was!
Anyway, I've just tested my search box and all records are being returned when I know that some should be omitted. I've just looked at the search UI and when I edit the search details shown in the list by clicking the pencil icon, the column pane shows some very strange listed items... e.g.: WADA_Insert_product or WAdbSearch1_product_results. Is this correct? Looking at your help info (yes, I have read it), it seems to show that you have DB column names whereas I seem to have session names listed.
Under the filter, I have the ability to choose 'Type: Keyword', and this changes the values of the fields beneath and allows me to choose columns from my DB there, but not all of the table's columns show despite having SELECT * in my recordset. There's 22 columns in my DB, but only about 7 showing!
Is the UI working as you would expect?
Anyway, the code I have is:
Search:
$searchWADAtbl_product_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"Includes", "join"=>"AND"), array("fld_p_name", "fld_p_descrption", "fld_p_collection", "fld_p_manufacturer"), "s", "search");
Recordset (on the same page as the above search):
$WADAtbl_product = new WA_MySQLi_RS("WADAtbl_product",$conn_mrs,20);
$WADAtbl_product->setQuery("SELECT * FROM tbl_product WHERE fld_p_show = 1 ORDER BY fld_p_timestamp DESC, fld_p_id DESC");
$WADAtbl_product->execute();
Search box:
<form id="Search_Basic_Default" name="Search_Basic_Default" method="get" action="rental-furniture.php">
<div class="input-group collapse">
<input id="search" name="search" type="text" value="<?php echo((isset($_GET["search"])?$_GET["search"]:"")); ?>" title="Search" placeholder="Search" class="search-box ml-auto">
<button class="btn search-btn" type="submit">&nbsp;</button>
</div>
</form>
Please see images attached for behaviour of the UI.
The only change I have made is to replace the rsobj.php file you gave me for a previous file... I wonder if that is affecting it?
Can I get a url to reproduce and FTP access? I'll take a look and debug it to see what might be wrong.
mrs
Oh ffs! I've just found the problem! Sorry for bothering you Ray.
It was as simple as discovering that id="Search" and name="Search" was missing from the button. It had nothing to do with the textfield, the recordset or the search array.
Thanks for you assistance as always.
